jcaplins
For those who have considered an auto engine...
Have you considered a VW VR6 engine for use in your RV. (If you had an RV6, it seems the VR6 would be fate)
I have a 2000 VW jetta with the VR6. This is not a normal V6. the "vee" angle is 15 degrees rather than the standard 45-60 deg. This essentially gives you a v6 in a slightly over-sized I-4 package (meaning narrow). Overall it's been a great engine for the road, and I wonder how well it would do in the air.
basic info:
2.8 L
174 hp @ 5800 rpm
181 Tq @ 3200 rpm
10:1
I'm guessing around 300 lbs.
(it's got AC )
Aaannnnd Discuss.
Really I'm in the process of replacing the alternator, and it is such a PITA with all the other **** jammed into the engine compartment, that I would rather remove the engine and scrap the car than try to get the new alternator in there.
basic info:
2.8 L
174 hp @ 5800 rpm
181 Tq @ 3200 rpm
10:1
(it's got AC )
Aaannnnd Discuss.
