Alex, great question.
The answers to the desired ring pressure over a wider range of time/distance were answered in the graph.
As for how the pressures work this video might be as good an explanation.
http://www.youtube.com/watch?v=tDk1TY-n0fM
The basic concept of combustion pressure applying radial ring pressure was settled 80 years ago. The bibliography in C.F. Taylor's The Internal Combustion Engine.. lists several research papers from the day. The best current pressure measurement information would probably require an SAE membership or similar, but you'll no doubt find reams on the net.
Practical example: Assuming a basic rectangular ring section, the standard has been about 0.0015" clearance between the top surface of the ring and its land in order to provide a path for combustion pressure. High RPM can float the ring within this clearance; some motorsports engines run a clearance of ~0.0005" and use drilled passages to port combustion pressure to the back of the ring land. Our Lycomings use wedge and half wedge sections, but the basic principles are the same.
Returning to focus...
The fundamental point in this conversation is that piston ring radial pressure is roughly proportional to gas pressure, and we require significant radial pressure for ring seating. That is why every break-in recommendation you've ever seen says "rich and high power", inter-spaced with short periods of light load to allow a degree of surface flushing and cooling. Failure to do so results in glazed cylinders and non-conforming rings.
Although LOP operation is a generally wonderful thing, it is not appropriate for all operations, and certainly not for ring seating. And yes, as stated, the reason is right there on the chart so kindly provided.
Dan, you have missed the point.
The area under the curve representing Mean effective pressure over a wider range, and further from the choke area.
At the nominal recommended 75% power or 80% power or whatever number you choose, the MAEN effective pressure is the determining factor is it not? As it is it is the mean pressure we want and not a peak.
The cylinder and rings have no idea what ROP or LOP is or means. They don't care even if they could care. All they care about is pressure, and they would not care how it is achieved.
By your logic why not run in the engine at 50dF ROP at 75% to 85% power? Draw your red lines on our graph and that now supports your argument even better.
For every bit of area under the curve on the left of the redline, to achieve the same HP, there is wastage on the right side. (Work in Vs Work out) Prior to your red lines starting at the peaks, there is a lot of high pressure over a very small distance travelled in the choke area. Compared to the green trace, which has less in that region, more work done during the region where you actually run the engine for the rest of its life.
So lets revisit a few things, what do we want to achieve?
Seat the rings?
Keep CHTs cooler?
Have high mean pressures with low peak pressures?
Peak pressures out of the choke area?
Keep the combustion chamber & oil cleaner?
So the choice is do it one way or the other. Its your engine, do what you like with it!
OK, so it is good that the peak pressure is lower and the pressure on the down stroke, (to the right of PCP) is higher, it helps the break-in as it = force against the cylinder wall. BUT, between TDC and PCP the pressure is lower - does that not adversely affect the break-in along this section of cylinder? No it does not adversely effect it, as in opposite of, everything after TDC is good however the less peak pressure in the choke area the better and the higher average further from TDC, is better, as is the normal running region of the cylinder during continued operation.
Are you just saying that this region of juste before and after PCP where the pressure is highest at 50dROP is better off with lower wear (break-in) relative to the other regions, so as to better balance the break-in process? I am not sure what you are getting at, I would suggest that you should not be running in the engine at 50dF ROP at all.
David, I think that when you say "higher MEP" is better that that peak lacks sufficient detail to understand why. Do you mean that break-in and resulting life of the engine would be improved if we hit the ideal of a fixed pressure all along the full stroke? Not sure how you would achieve a fixed pressure all the way along the stroke, but by having a higher MEAN AVERAGE pressure in each combustion even with a lower peak you will get the area under the green curve.
Either the full rich or the 80dF LOP high power curve is good. Full Rich is not a bad thing at all, just one method does all the same things and less of the less desirable things.
Thanks for your insights. I spent a decade ( at least) in engine performance and development, but mostly on diesel engines, some on natural gas. Not so much on the air-cooled spark ignited, only a couple.
Dan, you have missed the point. The area under the curve representing Mean effective pressure over a wider range, and further from the choke area.
High CHT.
So just visually comparing the blue trace with the green over the range from 60degrees either side of TDC, one would appear to have a meaningful pressure over a wider sweep than the other, and one has a more severe peak than the other.
Total duration of pressure is identical: ignition to exhaust valve opening. Average pressure is higher for the rich mixture.
High CHT.
Ahhhh and what would cause that high CHT I wonder.
Just lucky we are not trying to break in a diesel engine, as they run LOP
So the choice is do it one way or the other. Either is valid. There are advantages in one. Its your engine, do what you like with it!
Treat the engine right, run it in IAW Lycoming instructions and I am pretty sure the life will be +/- 5% of any of this clever stuff you can do.
Flame suit on..........
How was the cricket?
