I just completed fitting the baggage door to my -10 QB and not too impressed with how it fits. Top edge hangs outside fuselage skin contour by about 1/8 to 3/16. Doesn't look like much can be done about this now. How have others found the fit of the door?
As a tip to others, rivet the door hinge AFTER you finish riveting the perimeter frame to skin as this gives you a lot more room to place your set. Also I could not insert or remove the hinge pin with the door in place as the plans suggest so be careful here.
