Okay! Sooo, the stock block has various probes (water temp., oil pressure, etc.) going to the ECU. Would it work okay to splice into the wiring right after the probe and then run the wires to the EFIS so that the various functions can be monitored on the EFIS??? Would it degrade the signal output to where the ECU would have trouble reading it? I know that on the oxygen sensor I've seen where that can be done but nothing on the others. What do you think?? The alternate would be to install a second set of probes run to the EFIS which is doable. But I want to avoid if possible. Thanks, Dan
