Having a problem with attaching HS-904 to the front spar assembly. I have all the holes clecoed and remove one at a time and rivet. The material separates a small amount. I can easily stick a paper thru approx .003” thick. I would think these need to be tight against each other. This is in the horizontal stab. I’ve also tried using cleco clamps as well. What am I missing?
