Help finding a previous thread.
Nashpdman
Looking for a prior thread regarding Quick Builds. I believe the thread was a few months ago. The thread offered step by step guidance on QB's and where to start. The thread was like an unofficial set of instructions.
Thanks for the help.
Mike
Threads that havent been active for a month drop off the queue, but you can reset the filter by going to the bottom of a forum page and at the lower left corner is a block of choices for how you view posts in that forum. It is called "Display Options".
If you think you saw the post a few months ago, try setting the "Show Threads From" to the last year, instead of the default 30 days.
Then hit the "Show Threads" button.
When using the Google search method recommended above, use quotes to find specific phrases.
(Example 1) site:vansairforce.net: quick build
(Example 2) site:vansairforce.net "quick build"
Example 1 will search for results with the word "quick" and the word "build."
Example 2 will search for results with the phrase "quick build."
Notice there are far fewer search results for Example 2.
You can also combine search terms and quoted phrases to find more targeted results.
(Example 3) site:vansairforce.net: "red cube" mount
The google search is Boolean.
The search is boolean so you can use + and - . . . . .example Site:vansairforce.com RV10+quick+build -----it will find each work even if joined like quickbuild the parentheses will look for the precise letters and spaces within.
