HFS
I just got a set of first run (mine) Goodyear Flight Specials back from Wilkerson for a recap. I've only had one other set of caps (Desser), and I didn't think about this then.
Here's the question: Has anyone checked the tire balance only after capping to see if the Red "dot" needs to be moved? I did, and the answer in my case is yes.
As you can see from the pic, on this tire the red dot is now at the bottom instead of at the top (light side). The other tire did not have the red dot up either, but less offset for the lightest point. Also, the tire that was 180* out of "phase", was also 4 oz. (~5%) heavier - don't know what that means. I balanced all of the rotating mass (shaft, nuts & hubs) beforehand to remove any "masking" of the real issue.
YYMV - And probably will, but I'll mount tires to wheels according to my "new" marks.
HFS
HFS
