Baggage area floor thickness
riobison
Gents,
Looking at installing some rivnuts in the baggage area and I was wondering if anyone would know the thickness of the floor skin?
Thank
Tim
I think it's 0.032". I did the rivnut thing as well for some of those spring latch baggage tie-down gizmos.
.025 2024- T3 alcad
+1 Right from the Parts Index Sheets. Not very thick for retaining baggage with a couple of rivnuts. Did you mean nutplates? Consider attaching to the underside of the baggage floor rib flanges.
Thin
The baggage floor is thin. I cut 2 pieces of 1/4" plywood to cover the floor and provide a little more support when I was building.
Baggage tie downs
Assuming you're thinking about a nut for a tie down, I'm planning to put the nutplates on sections of 3/4X3/4 aluminum angle or maybe J-Channel nested and riveted under the floor rib. There's a lot of tension on tie downs. I want them secure. Plan is to install four in the corners.
I basically did what Larry ^^^ is suggesting, I put some 3/4" angles as reinforcement on the top baggage rib flanges out in the four corners & fitted #10 nutplates. I used the two-piece tie downs Vans have in their shop, so the base is permanent on the floor and I can put in the spring-retained rings as/when needed. I might even have a photo I can share somewhere.....
Need the specs for the grip range on the rivnuts.
I didn't build it so I dont have the specs. I see that Vans will sell the plans on a USB stick so that is on my to Buy List.
Building a bracket to mount my O2 bottle to. I agree that I will need to attach it to the aluminium angle or j stringers to have any holding strength at all.
Tim
