I cannot get the FF-00122 aluminum tube to fit inside the rubber neck of the air filter in this assembly. The inner diameter of the filter is about a 10th of an inch smaller than the aluminum tube. I am nearing destroying the filter trying to get it to fit.
What am I missing?
I’m assuming the rubber neck of a filter protrudes through the FF-00120 and is clamped onto the aluminum tube. Is this not the case? If it is not the case, wouldn’t that create a metal on metal situation between the aluminum tube and the aluminum FF-00120 ?
What am I missing?
