hosspowerinc
Active Member
Sold
Sent messageI'm selling a freshly IRANed O-320-A2A. The engine sat for 12 years and had corrosion on the cam and accessory gears so they were replaced with yellow tagged parts along with new bearings, rod bolts, and oil pump gears. The engine only had 530hrs since major so the cylinders weren't reworked again but the bottom end work meets the Lycoming overhaul spec. Mags have 407 hrs since new. I have logs since 1959 and 353hr TT. This is a conical mount, narrow deck engine originally from a PA-18 and the lightest 150hp that Lycoming made. Comes as pictured, no additional accessories. Located at KRHP. $18,500
