I'm considering adding a "rotating" red beacon to the top of the fairing of the vertical stabilizer of an RV-7.
The wires will have to go through the forward "bay" of the VS, and the good thing is that there are only two ribs I need to go through: the top and the bottom one. The bottom one has a lightening hole, so all is good there. The top one I can drill for a wire, no problem.
However, the question is, how do I support the wires inside that bay?
Doing a surgical operation through the bottom lightening hole to glue some cable tie supports on the front spar sounds a bit unrealistic.
I can tie wire to something stiff, maybe, a solid carbon rod, then attach the rod with two clamps, at the top and at the bottom. How does that sound?
Other options?
Other options?
