Sub panel/Avionics "bay" ideas
Freemasm
Care to share any of your subpanel and avionics bay construction ideas? Pix would be great.
Between EFI/EI, avionics signal converters, remote devices, etc. It's going to get crowded back there. Much thanks.
Danny, I'm curious about your control cables. What type and where did you get them? They look a lot nicer (maybe read that as more expensive) than the standard ones provided by Vans.
Not sure which “cables” you are referring to. The rudder cables are standard aircraft cable.
Danny
Here is a photo of a tray that sits behind the efis screen. It could give you some additional options for mounting remote components. (you need to visually rotate the photo 90* counterclockwise)
