seanfranklin
I'm New Here
Hi, Does anyone know the safe tire pressure of rv3b 3.80x150 600-5 6? Thanks for helping!
Let’s see - the question is on an RV-3….two answers for other planes already!
We actually run fairly low tire pressures on our -3 (28 psi) because that is the sweet spot for damping out gear shimmy. We run considerably higher pressures on our other RV’s, but this is the number that works with our gear dynamics. If I can find the time to play around a bit, I want to convert the -3 from wood dampers to metal, and see if that works well and I can raise the tire pressures….but I have other projects with higher priority!
Paul
