I bought a used 2015 RV-10 with about 300 hours on it. So far, I have flown an incremental 50 hours or so. The other day the whole panel started flickering on and off while the aircraft was running. After shutting down, I traced the main 8-gauge electrical wires from the breaker panel to an 80-amp fuse mounted on the firewall. I noticed that the fuse had cracked from engine vibration, causing the electrical system to flicker. See attached photos.
I have never seen this before. Is it normal to have an 80-amp fuse mounted on the firewall? Has anyone else seen this design before? I am tempted to just bypass the fuse permanently since it is now a known weak point in the electrical system design and I don't see why it would be useful.
Thoughts? Any better solutions out there?
