New Builder Tool List (RV-10)
kirkbauer
(could be moved to the RV-10 forum, however I assume a lot of this is pretty generic information)
I'm becoming a semi-expert since, due to LCP, I have built about 1.5 RV-10 empennage kits. I had some trouble early on figuring out what tools I needed. I bought some bad tools and I bought some great ones. I wanted to pass along that information to help future new builders. Once you get your tools, I recommend buying (and building) at least two of the "RV TRAINING PROJECT-1" kits from Van's to get started.
Start with the full RV-10 tool kit from Cleaveland Tools. If it still works the same way as when I ordered it, you receive a discount on your entire order when you buy that kit. So it might make sense to order some of the extra items (that I have listed from Cleaveland below) at the same time.
Cleaveland Kit
Here are a few specific things I am glad that I upgraded, and other things that I didn't end up using. In general, the kit has a ton of what you need.
DrillN/A: Used my existing Makita drills
C-Frame DimplerUpgraded to DRDT2 (worth it)
SqueezerSNB214 (could not imagine using the manual one)
1/8" Dbl Offset Cup Rivet Set - RSCX4Do need it, even for QB -- Van's says not needed for QB
3/32" ClecosSuggest an extra 100 (sometimes they go bad)
1/8" ClecosSuggest an extra 25
Tungsten Bucking Bar - BBT41Very useful, but you'll need others too (see below)
Threaded Micro Stop Countersink Cage - CT196Yes, but I would recommend buying two extras so one can always be #40, one always #30, and one that moves around
3Pc. Aluminum Deburr Handle Set - DBS33Don't love it, have other recommendations below
Hex Shank Hole Deburring Tool (EXCLUSIVE by Cleaveland Tool) - DB04Don't love it, have other recommendations below
3M Cut & Polish Wheel - 6" - 3MW7A6You'll need more than one to finish the whole airplane, perhaps get an extra
3M Scotch Brite Red Hand Pad - 3MP47Need many more if you are priming, but perhaps buy in bulk elsewhere
One Piece Rivet Gauge - EXCLUSIVE by Cleaveland Tool - RLG1I have one I like better listed below
Van's List: Optional Specialty Tools
Angle Drill Kithttps://cleavelandtool.com/collections/toolkit-angle-drill-attachment-kit
Dimple Die OrganizerCleaveland DIEB10 (in kit)
Rivet Measuring Gauge (I like these better because I can only grab the one I currently need and don't have to remember which gauge to use)https://www.aircraftspruce.com/catalog/topages/averyrivetgauge.php
Edge-Forming ToolCleaveland EF60 (in kit)
3/32" Pin Punchhttps://www.aircraftspruce.com/catalog/pnpages/12-00870.php
1/8" Pin Punchhttps://www.aircraftspruce.com/catalog/pnpages/12-00871.php
In-Lb Torque Wrench (mostly don't need until section 11; assembly)https://www.amazon.com/gp/product/B0C65D11MY
Van's List: Standard & Optional Shop Tools
This is a partial listing of the standard and optional tools that Van's suggests.
Pop Rivet Tool (manual) -- sometimes you need to access small placeshttps://www.aircraftspruce.com/catalog/topages/heavydutyriv1.php
Pop Rivet Tool (pneumatic) -- the manual ones kills my hands; this is incredible for the price, when access isn't limitedhttps://www.amazon.com/gp/product/B077JLMZ97
Hearing Protection -- I wear these almost 100% of the time so I can listen to Bluetooth while workinghttps://www.amazon.com/gp/product/B0723CYHPZ
Drill PressI feel like it is required
Band SawI feel like it is required
Band Saw Bladeshttps://www.amazon.com/gp/product/B07T3Z95J9
Bench Vise Jaw Pads -- nice to protect the item you are working withhttps://www.amazon.com/gp/product/B07848T22X
Cut-off saw with blade for metalSometimes you'll need to make cuts that won't fit on the band saw
Deburring Tools & Supplies
Speed Debur -- I use this for all holeshttps://cleavelandtool.com/products/speed-debur-and-countersink-set
Bench Grinder -- I put one 6" 3M wheel on thishttps://www.amazon.com/gp/product/B07T3L1T8S
Die Grinder -- very useful for deburring skins and lightening holes using both the 2" and 1" wheels belowhttps://www.amazon.com/gp/product/B000VYZ1HW
3M 1/4" Mandrelhttps://cleavelandtool.com/products/3m-1_4-mandrel
3M Cut & Polish Wheel 2" (several)https://cleavelandtool.com/products/3m-cut-polish-wheel-2
3M Screw-On Mandrelhttps://cleavelandtool.com/products/3m-screw-on-mandrel
3M Cut & Polish Wheel 1" (several)https://cleavelandtool.com/products/3m-cut-polish-wheel-1
Dremmel Polishing Wheels (several packs) -- I use this all the time to help with hard-to-reach edgeshttps://www.amazon.com/gp/product/B075C72PGK
Dremmel Sanding Drums -- I use occasionally for heavy-duty sandinghttps://www.amazon.com/gp/product/B07NVGBSRT
Riveting Tools & Supplies
In addition to the one bucking bar in the Cleaveland kit, I use these and other accessories.
Rivet Caps -- help prevent skin damagehttps://www.aircraftspruce.com/catalog/pnpages/12-03364.php
Flush Rivet w/ Rubber Ring -- help prevent skin damagehttps://www.aircraftspruce.com/catalog/topages/flushrivset.php
Rivet Tape -- for back-rivetinghttps://www.aircraftspruce.com/catalog/cspages/3mRivetersTape.php
Tungsten Bucking Bar -- primary onehttps://www.aircraftspruce.com/catalog/topages/buckingbar12-04866.php
Bucking Bar A -- for hard-to-reach placeshttps://www.aircraftspruce.com/pages/to/buckingbars/buckbara.php
Back-Riveting Bucking Bar -- for back-riveting when you can't use the plate (e.g. tailcone skins)https://cleavelandtool.com/products/back-riveting-bucking-bar
Clamps
I didn't have a good supply of clamps and I find myself using each of these at various times
Other/Misc
Full drill bit set -- nice to have all of the sizes availablehttps://cleavelandtool.com/products/drill-set-numbers-1-60
Flange-nose Pneumatic Yoke -- must-have in addition to the yoke in the Cleaveland kithttps://cleavelandtool.com/products/25-flange-nose-pneu-yoke
Tap & Die (Wrench only) -- I can't recommend my cheap Tap kit as the handle broke. And another handle broke. But this handle you'll be passing down to your grandchildren.https://www.amazon.com/gp/product/B0006J4DNA
Socket Sethttps://www.amazon.com/gp/product/B09FSZW427
Angle-Finderhttps://www.amazon.com/gp/product/B09YPTDG65
Scale (for fuel tank sealant)https://www.amazon.com/gp/product/B07SL2TBBD
Shop Vachttps://www.amazon.com/gp/product/B06XKD57YF
Center Punchhttps://www.amazon.com/gp/product/B0B8HCRM4Y
Detail Sander Set -- Use to scuff the skins where the sealant needs to attachhttps://www.amazon.com/gp/product/B0B1C3ZTYV
Safety Wire .032 SShttps://www.aircraftspruce.com/catalog/pnpages/05-02685.php
Rod End Bearing Tool (can make your own or buy one; need for section 11)https://www.aircraft-tool.com/detail?id=AE408
Torque Seal (for marking properly-torqued nuts; need for section 11)https://www.aircraftspruce.com/catalog/cspages/crosschecktorqueseal.php
AN Bolt Gauge (really helpful for identifying bolts, especially in section 11)https://www.aircraftspruce.com/catalog/hapages/boltgauges.php
Priming
If you are going to prime before assembly, this is what I use in my process.
Fiberglass -- don't need this until section 12 where you do your first bit of fiberglass work, but this is helpful to get started: https://www.rvpilot.com/Fiberglass/fiberglass.html
I hope this helps somebody else save some time and money!
PS - my final tip. It seems almost guaranteed that you'll mess up some skins. If you do the VS first then that seems the most likely to be damaged. Perhaps see if you can pre-add a second VS skin to your empennage shipment to potentially save a lot of money on shipping. My third VS skin looks great! Also, the rudder is your second part, and the two skins are the same part number. So perhaps consider adding one additional rudder skin as well. Then it won't hurt so bad when you need to start over on one of the skins.
Thank you!
This list has been invaluable!
Glad to hear, thank you! I wasn't sure if anybody had seen it. Here are a few additions I just made after finishing Section 11:
