McCauley prop governor dressing
tracy
Friend
I’ve had a small leak for years on my McCauley prop governor gasket. I’m having it overhauled and was wondering if there is any sort of sealant I can put on gaskets to creat a better seal? I was thinking hylomar universal, or hylomar blue.
Are you sure it’s the gasket that is leaking and not one of the studs where oil is wicking through the stud threads ?
Alternatively could it have been the seal between the Govenor Body and the Govenor Baseplate? There's an o-ring in there that could have weeped. Just a thought.
No, what could be done there?
A look at the lycoming parts manual illustrates studs that could cause oil to weep through the threads.
I have had success stopping weeping by applying high temp thread sealant to the studs going into the accessory case and governor drive assembly.
