FireMedic_2009
I wasn’t wanting to spend $600 for the Van’s fuel pump and was wanting to use an automotive pump. On the RV6A I owned the pump had a return line going back to the input side of the pump. I assume there is a check/pressure valve on the return line so once the output of the pump reaches a certain psi the fuel loops back through the pump to keep the fuel from cavitating in the pump as well as over pressurizing the system. So I’m looking for part numbers for the manifold and check valve and where to get them.
I have a fuel injection engine
