Another thread asked if your mind wanders while you work. Well, I've been shaping clay for upper gear leg fairings and what comes to my mind is "gotta to be a better way".
I've done the clay thing previously. I've also used male forms made from foam and coated with tape or a filler, but usually they have been larger components, often incorporating a lot of straight lines. I can sand foam much closer to a desired contour as compared to working with clay; a fairing made over a close-contoured shape needs much less filler and finish time (example below). Trouble is that foam blocks would be kinda hard to fit for gear leg intersections.
Anybody found a spray can or 2-component mixed foam that when cured has small cell size and good shaping properties? Foam might work well if you could spray it or blob it into place.
