I'm modernizing my 2014 RV 10 panel, for sure getting rid of my old Chelton EFIS screens and my unusable standby instruments. Just received estimates for 2 new Garmin G3x screens, G5, & associated hookups.
Also gotten estimates for new autopilot to smoothly interface with the panels.
Might also get the Garmin 750xi & engine display kit.
Any major advice in this decision? I plan to do lots of traveling across the country and want to be as worry-free as possible. Thanks
I've got 600+ hours on dual screen G3X with GTN650. Here's my infinite wisdom -- or something like that.
I run both G3X screens in split mode: engine instruments on the outside, flight instrument in the middle of the screen, and "MFD" tpwards the center of the airplane. This means that in the left seat, I essentially have two MFD screens. There's no point in running the right side screen full size, because most of the information is in the middle of the screen, and running the display full screen only moves the useful information farther away.
The parameter bars above the screens are real handy for all kinds of flight data! The Garmin ads show lots of frequencies and such up there, but that's suboptimal on two counts: dedicated knobs are faster; and too many frequencies etc reduce the number of parameter you can show.
GTN650 or 750? I'd go for the 750 in a heartbeat. It gives you another display screen; it makes flight plan editing easier; and it gives you ILS frequency displays, along with the Morse ID and the database ID without taking up any of the parameter bar. Yes, you can get by with just a 650, and I've done it for years, but if an upgrade was feasible in my plane...
Engine display? Not needed. On the G3X, all the engine information comes up just by touching the engine display column, and summary information is plenty good. Worse, a dedicated engine display will just move the right side MFD farther away.
The G5 doubles as a standby AHARS, a nice feature.
I would consider somehow mounting an aera 660 or some other Garmin device on the panel, or easily mounted. That can be a standby GPS in case of total electrical failure, or alternator failure when you need to load shed. Don't know how feasible this is, though.
The Garmin autopilot is nice. And you can get a yaw damper that the back seaters will appreciate.
I'd offer you a ride to check things out, but the shop still hasn't written up an estimate for Smokey, and there's a whole continent between the two of us.
I've got lots more ideas to share if you're interested.
Be well!
Ed
