Budget VFR Panel...
I’m re-building a 6A. The original panel was analog with cast-off, but functional equipment. Items from Piper, Cessna, Terra, etc. were used in the spirit of simplicity and low costs. I don’t think anything was purchased new for the original panel. I’ve tried to keep that theme going from the original builder.
A friend was able to scrounge a big piece of .063” 2024 from a dumpster. A friend put a nice 90* bend on it with his brake. After a few hours in & out of the -6, I had the basic blank. I added .75” extra to the lower portion. Still high enough to clear occupants’ knees. The only new item on the panel is the GTR200. It’s just too good of a value on a single COMM / VFR aircraft to pass up. Even the air vents were scrounged from the dumpster. I’m amazed at what people will throw away.
I’m currently working on wiring the panel, at home. 115*F is too hot to be working in the hangar.
This is what I had to start...
Current progress
This is what I’ve been able to get done...
Here is my panel evolution. Original, 1st upgrade from last year and the newly finished panel.
Day VFR to full Glass conversion
Not 100% done with electronics, but my dash is new and cut and powder coated.
RV6 Panel
Here's my old school panel. 180 hp// fixed pitch .Super light.I love it. (.....because I was inverted ....;)
Here is a picture of my Panel. Had it made for me Carbon Fiber.
RV-6 panel
My RV-6 panel installed 2014. 2021 upgraded to Dynon HDX and Aero 660.
New RV-6A
Day VFR RV-6A trying to keep it light and simple. Trial fit before priming and topcoat paint. Final installation will be after the windscreen has been fitted.
IFR Panel (Dynon with a Garmin 175) to powder coat to tomorrow.
Going to look and work good.
Panel design (removable middle section) has been a good learning experience. AFS support is great.
SNIP
You will never regret taking the time now to end years of pain from a panel that you have to crawl under to do anything.
Of note - I’m working a panel for an RV-6A builder (Dual SkyView, GPS-175 and Garmin NAV/Comm). On this panel we made a bottom apron (like the stock RV-10 panel) to mount all the stuff that stays in the plane when removing the panel (switches, cabin heat, engine control cables and such). Once the top portion of the panel is out you have full access to all this stuff. When installed, panel plus apron height remained the same as the stock RV-6 panel.
Never on your back with your head under the panel…..
New RV-6 panel
Here's a new panel we just completed for an RV-6 in our hangar. From mid 90s VFR to modern IFR for a local airline captain.
I've had my 6.9i since 1 December 2018... quite a few hours of avionics yoga were spent under the riveted panel, wedged between the manual flap handle and the throttle quadrant... from a pure VFR yellow panel into today's latest iteration :)
PS
The right side of the panel is usually covered by the iPad mini in a Xnaut cooling case on a RAM mount running the very popular (on the old continent) SkyDemon app.
From 1990's VFR to modern Garmin! RV-6A
PS
What's on your firewall ?
Aaaah... no clue since I'm not the builder. But it is some kind of sound isolation alu foil covered mat about 5mm thick, and knowing the pro builder, must be fireproof too.
The old panel, quite neat for a steam gauge setup but it was hiding some egregious wiring crimes and the partial remains of a vacuum system.
I ended up replacing all the wiring and starting fresh, requiring quite a few hours in the following position
At the same time I went through the entire plane and fixed anything that needed it and replaced anything made of rubber, or otherwise old and worn. The other big one was conversion from a wood fixed pitch to a constant speed Whirlwind. It was a tricky job to modify the quadrant for an extra lever, but it all worked in the end. Installing the crotch strap for the new 5 point Crow harnesses took most of a week also, though well worth doin.
Since the tipper canopy panel removes with just a few screws, I put everything through a big milspec connector, except the audio which has its own connector. This makes removal for maintenance super quick. All the switches are APEM milspec parts, no automotive grade nonsense here!
Since taking this photo I’ve mounted the iPad back where it was before, which is why there’s the USB power on the new panel
For UK/Europe touring I think this is just about perfect. It only has an O320 but an empty weight of 1030lbs :)
IO390,
Beautiful work! Nice looking plane! May I ask what the white plastic items are around the larger wire bundles? Plastic adel or "P-clamps"? And what is the black under them? Looks like a great way to tidy the bundles. Stealing ideas for a Bucker panel I'm wrapping up. Thx!!
Bob
IO390....
I just noticed that your struts are mounted up side down. If you flip them over, the canopy will slow it's opening speed for the last few inches and not come to a clunk! as it tops out.
IO390,
Bob
Thanks! They’re just nylon P-clips as you suggest. I put some tesa wiring loop tape around the wire where it’s clamped. Some example links:
