What is this clamp called ?
This is a AN737-TW clamp. Has the numbers 74 and 91 on the band also. Also says Wittex 301. These were used on a 182 with a 470 Continental I used to have. They went around the hose that joins the induction runners. Where can I find these ? Is this a factory made clamp or did some one make this ?
Charlie
Double clamp...
Charlie
I remember seeing these on the C 180/182 series. This one looks shop-made. The corners are not rounded and the edges pf the cross-bars are not straight, as you would expect to find on a mass-produced, factory-made part. The shop head look like they are out of a......well, a shop! You could probably make one for WAY less than Cessna would charge you.
This clamp or similar is used on the induction tubes of the IO-550B on my Navion. It is Continental P/N 629163-5.
