You should mount the unit as near in line with the mains as possible, you want the altitude to be based on the mains, not the tail. I installed the USB pigtail just because it was easier to do at the initial install/wiring, than do at a later date if i ever need it. I share no CB's on anything i have installed. Everything is on its own protected circuit with recommended circuit protection rating. i tapped into my roll servo can bus to keep can bus as short as possible.
