Brantel
So for those that have done this before, which direction should the flange on this little triangular gusset face? In toward the occupants or to the outside toward the skin and vertical brace? Seems to make sense to have it point outboard so nothing can catch on it but the drawings seem to have it pointed inward but it is very hard to tell since the drawings are small. I think this ends up right under the instrument panel.
Next question is on the aft end of the longerons, the side skins have this temporary extension so you can match drill the tailcone mating holes. Well it appears that when Van’s pre bends the aft end, it bends the longeron down a little. The side skin while flush with the vertex before the bend, it is not aft of the bend. What did you do? Did you just drill the holes at an angle or did you attempt to bend the longeron back up? Both sides are virtually the same.
