Mousse
Anyone has a spare sniffle valve for my IO-360? And is there an alternative to such a valve?
Michel
I second the Airflow Performance manifold drain. With my Superior sump and cross-over exhaust, the Lycoming sniffle valve didn't fit well. The Airflow Performance product allowed for a better fit, and it is a dirt simple b-b in a standard looking fuel fitting.
John Tierney
Drain excess fuel from the sump is the main reason, a backfire into a sump full of fuel can ruin your day.
Thank you all. I, also did not know this drain could be used as a sniffle valve. One manifold drain on order.
Michel
