Sanch627
Garmin GTR 200 nav com on lower left, Garmin GTX 335 transponder ADS-B right.
Chris
RV4 N1212R #4633
The panel looks great!
I have wanted to go with bare aluminum on a couple of projects but chickened out thinking it would be hard to maintain and have glare. Have you considered jeweling it?
4 Panal
I have thought about Jeweling or machining as it sometimes called, Spirit of St.Louis cowling. Just might happen.
Chris RV4 N1212R
Shiny panel :(
I thought the shiny panel was just temporary while doing the mock-up.
Having been nearly blinded by just the EFIS and various pad screens, I would definitely recommend against shiny and glossy panels in an RV-4 or similar.
Finn
Have you had the panel in the fuselage yet? You'll most likely have some interference with those radio racks and the F-402C bulkhead member.
A lot of RV-4 panels have cut into this bulkhead, but just so you're aware, it is cutting into a fuselage bulkhead structure member. I've also shown a picture of my instrument panel where the transponder on the lower left is as low as you can go without cutting into structure. The top of F-402C is level with the canopy rails.
My panel is also 1" shorter from the bottom edge than the plans show. In other words, on a plans sized panel, there would be 1" additional inch of panel space from the bottom edge of the panel to the lowest a long radio rack could be placed without cutting into the bulkhead. The transponder rack is literally sitting on the F-402C bulkhead in my airplane.
Bulk head clearance
Yes, all that has been taken into consideration,it will have to be modified and reinforced.
Chris
And now for something completely different.
Moving right along.
