larywil
Member
Patron
Has anyone installed a single axis Autopilot in an RV-3? Has anyone added some means to extend fuel supply in a -3 That has a fuselage tank? Thanks in advance.
RV3 Autopilot
I was about to post the same question. It would be great to know what you find out. I am just looking to add a single axis. LMK if you get anything from the powers that be at the VAF.
I’ve got a dual-axis autopilot in our -3, so a single axis shouldn’t be a problem. I have also seen at least one three with both wing and fuselage tanks - but the surgery would be extensive to install standard wing tanks in an early model airframe…..
The "easiest" way to get wing tanks would be to order RV-3B wings (quick built still available?), drill out and replace the main spar bulkheads in the fuselage and mount the new wings with tanks.
Another possibility would be to convert the wingtips into tanks. I think that someone used to produce such.
Don't do what I did. My RV-3 project came with wings mostly done. In order to do the main spar modification I had to drill out rivets and peel back bottom wing skins. Because I then had access to the inside of the wing I pop-riveted closed the holes in outer and root ribs, drilled holes in top skins for filler cap flanges and coated the inside of each bay with angelhair (thin fiberglass) and epoxy, and pop riveted main spar lightening holes closed (with epoxy). Worked great for a while but with repeated hot/cold cycling from sitting outside all the time in the Florida weather (and possibly from ethanol in the MoGas I used) they started to leak. I anyway mostly used the 25 gal fuselage tank, and really only used the wing tanks for flight to OSH and back (taking care to use the fuel in most leaking wing tank first). OK, you can all stop laughing now!
Finn
Autopilot
I have installed an old single axis by Trutrak that was given to me. It will track
a GPS course. It's not much good with the ride gets a little rough.
Wing(tip) tanks
http://hotelwhiskeyaviation.com/rv4
In an RV-3 with no wing tanks the same principle could be applied giving you maybe 8 gals in each tank by having the (round tube) tank extend all the way from root rib out into wing tip. If you can find a thin wall alum tube that will fit into biggest forward rib lightening holes you could find a welder that could weld the ends shut, weld on drains, filler caps, etc. Suspect you'd have to wrap the tube with anti-abrasive tape (similar to what's used under top skin/flap).
Of course you'd have to remove the wing tips to install them. Well, first to ensure there indeed are lightening holes in all ribs. Not sure the weight and cost would be worth the extra fuel capacity.
Finn
