Tucky Bourbon
I'm New Here
First post, please be gentle
Got a question: I'm building my RV-8 with a Lycoming IO-360 A1B6, and I already installed the MT P-860-4 governor before realizing that the 300RV came with a Jihostroj P-920-032/A governor. Do I need to remove the MT governor and replace it with the Jihostroj or will the MT work just fine? I'd really like NOT to have to do that as that would be a real pain in the butt. So far I see the gear ratios are the same, but I cannot verify the MT governor's relief valve is compatible with the 300RVs 330psi maximum.
Can anyone verify if the MT governor will work with the 300RV prop?
Chris
Chris
