Gt-401
We have been doing a surprising amount of cross country flying in our 180 horse Harmon rocket, and it has brought up a couple comfort issues. One being, having to loosen the shoulder belts every time I need to switch tanks, or adjust the O2.
Does anybody have retractable harness installed?
Simpson says ...NO.
Just read a detailed article from Simpson harnesses, and I'm sure I remember them saying that retractables allow too much motion during a crash before they engage.
It was in June 2019 Sport Aviation...
Give the belts a good hard jerk and see how much slack there is before tightening. Probably be fine; this's what they're used for, after all.
A couple things..
There have been retractable harnesses for decades in many aircraft (all airliners) and a bunch of old warbirds, some of which are lockable when you are in turbulence, combat, ect. I have flown with them, and toyed with putting the airliner type in my -4 , but decided after bumping around on those bumpy days I was just fine setting my fixed harness to the required comfort level. I still have my airliner designed inertial reels on the shelf in case I decide to give them a whirl, and I believe they would handle a crash just fine (that's what they were designed for). Keep in mind, the attaching geometry is different, and may require unique mounting considerations.
Doesn't really answer the question, but I generally slacken the shoulder straps when in cruise. Take off, landing, or big bumps is the only time they are tight on a cross country mission.
Keep in mind that the distance between your head and the glare shield is quite a bit different than Boeing/Airbus/F???. That extra inch of give might just be too much.
A friend of mine installed these in his plane, and he likes them a lot, they have a handle to manually lock the harness, which I think would be good for aerobatics, or turbulence. They seem to be the best of both worlds. I'm just wondering if anyone has installed them in a rocket or rv-8? where could the inertial reel go?
