mc607
I’m almost done my panel and just GEA 24 left to wire. I’d like to populate everything now, rather than wait til the engine is mounted. Can anyone provide lengths for the CHT and EGT sensor wires? My GEA is mounted on the aft side of the sub panel behind the PFD. But if you can provide lengths based on your GEA location I can figure it out from there. Stein allowed for 8’ in my order for each of the 8 runs, but I’d rather not waste wire if I can help it. io390 dual pmags Van’s exhaust.
Todd
Every installation is different, I would suggest that you go with the 8" provided by Stein.
This will give you flexibility to route the wires the best way which may not be the shortest.
Good luck
Good luck
Thank you for your reply.
