szicree
I'm going to be using a fuse block in my RV4 and am wondering what the conventional wisdom is regarding location. Also would like to know about where folks mounted the ground bus.
Steve Zicree
RV4
Fuse block location
You can put your fuse block anywhere it's convenient. Since you won't be trying to change fuses in flight, just put it wherever makes most sense for your installation.
Fuse block
On my RV-4, I mounted 2 fuse blocks in my control panel on the RHS (one block is primary and the other is avionics). Heres a photo.
