acpilot
Patron
I just assembled my 2 Quad Spot landing lights for my RV14A. I was playing with the Vans landing light bracket trying to figure out the best way to adapt it for the Quad Spot lights. I have seen a few pictures on VAF, however, the landing light board is not quite the same as mine. I was thinking of just adding a couple of nut-plates to the back of the Vans bracket and screwing the board to them, but wondering if there is a cleaner way to do it with the board behind the bracket. Anyhow, just curious if anyone has any pictures of the way they mounted them. Thanks
I did exactly as your describing except used 4 screws and nuts to secure (match drilled into the bracket). Put a snap bushing in the W-00017 so the power/ground wires can run to the front and up to the terminals. The downside is they are not easily aimable this way. I’ll shim it if necessary. Good Luck !
