Steve Barnes
Going to install ADSB-B in and out and strongly considering Skybeacon for a flying RV. Looking for pros and cons.
Thank you
Steve Barnes
Skybeacon only provides ADSB out. Simple install. Dependent on how decent your existing transponder is so make sure it is working correctly. Will need to tweak the threshold value (lots of threads on here about that). Can be installed in the wingtip if that is a configuration that might make sense for your specifics.
Wing tip mounting
I mounted mine inside the right wing tip, working as it should. I did not want to give up my tail strobe light.
