Taltruda
Friend
Preparing to convert my -4 from Carb to bendix style mechanical fuel injection. I have an updraft sump, what should I use for throttle and mixture brackets? Will my carb brackets work? I see AFP has brackets for the FM150, do those fit the RSA-5?
Vans has two different brackets depending on whether you are fuel injected or carbureted. So your existing bracket probably won’t work without modifications.
