Derek343
Member
I'm flying my RV-3 in Colorado and it has been very cold. I want to put in some cabin heat. Has anyone done that and/or suggest how to do it.
I don't have any vents installed. It has an O-320 engine. The only vent is a pop out of the side of the canopy.
Looking on the vans site, it looks like I could do this:
https://shop.vansaircraft.com/cgi-b...rowse=heatvent&product=ventilation-components
Complete vent system for one seat with drawing and instructions
VENT SV-COMBO
$25.00
https://shop.vansaircraft.com/cgi-b...73871-184-165&browse=heatvent&product=flanges
Flanged duct for penetrating bulkheads
VENT 2" FLANGED DUCT
$21.00
https://shop.vansaircraft.com/cgi-b...4-165&browse=heatvent&product=cabin-heat-muff
2" HEAT MUFF
VENT DL-05 2"
$120.00
https://shop.vansaircraft.com/cgi-b...165&browse=heatvent&product=heat-selector-box
Stainless mounting plate/tube, shaft and selector door, w/2" dump tube
VENT DL-01SS
$136.50
Heat selector control cable
CT A-740 BLACK
$45.00
https://shop.vansaircraft.com/cgi-b...&browse=heatvent&product=scat-tube-and-clamps
SCAT tube 2" dia. x 3' long
VENT SCAT 2X3'
$33.00
Would this work?
It says
Box mounts on the engine side of the firewall and either routes warm air to the cockpit or dumps the warm air overboard. Air heated in the heat muff must continually flow to keep from overheating components and destroying items such as the muff or the scat tube. Requires control cable to select heat on/off.
What do you do to dump the hot air? Do you vent it out somewhere?
What you are describing is the basic cabin heater in all RV’s. The “unused heat” goes out the bottom of the cowl when the heater valve is closed.
In our RV-3, we added an electric seat heater as original equipment - it does much more to keep the pilot’s core temperature up than the standard cabin heater (which we also have installed).
Becasue of the bubble canopy, there are two “heat zones” in the airplane - above the sill and below the sill. In cold conditions, the cabin heat does fine with everything below the sill, but the upper body and head can get chilly - unless, of course, you’re in sunlight, which really makes you comfortable.
Leaks are a priority
As Paul says, the standard muff/ firewall valve puts heat in. My biggest source of cold air was the rear canopy to fuse seal and flap pushrod holes. Foam does a pretty good job on flap rod leaks. I cut a 1/4” craft foam board from hobby lobby to seal the seat bulkhead to the canopy. Just remove it for summer. And of course, stocking caps a good thing .
