How'd you get from bottom of engine up through upper cowl area? Did you drill a hole through baffling for the wire?I had to extend my original wire so I could plug in by the oil door. Would be nice if it came with longer lead plug.
My oil access door is aft the baffles so the wire just comes from the bottom pilot side drain plug and comes up the back the engineHow'd you get from bottom of engine up through upper cowl area? Did you drill a hole through baffling for the wire?
I like that clamping mechanism to secure the plug. Mine is just tied right onto the engine mount and the plug head flops around. I feel like I need to copy this.I found the wire to be plenty long, easy to route as shown.
