RV-4
Hello everyone
I just installed a Taibeacon-X in my -4 and as I'm new to this I was wondering what traffic should I see on my 796 ?
I know that I should see all ADS-B traffic around me ( which I do) but should I also see the other ''Transponder equipped Mode-C traffic??
I was flying a loose formation with a friend the other day and he ( he's ADS-B IN equipped ) could see me ( it means my ADS-B OUT is working I guess ) but I could not see him...
Is this normal or is there something not up to speed with my installation??
( If you have seen my previous post of my Tailbeacon-X installation in the wingtip of my -4, I will be replacing the aluminum bracket with a fiberglass bracket as it may have shielded the antenna on a couple occasions as reported by ATC..)
Your imputs will be appreciated
Bruno
[email protected]
Unfortunately, no. Seems all development on affordable MLAT traffic systems has stopped - we're all waiting for everyone to just buy ADS-B.
Here's a prediction - someone will come up with a traffic system that uses cameras which will be more helpful and more accurate than even ADS-B. I'd do it, but I'm too dumb, too old, and too lazy!
To see transponder only traffic, here in the US:
You communicate with adsb ground station. ATC radar sees other aircraft, sends info to ground stations. Ground station sends it up to you. Since you’re in Canada I don’t think you have ground stations, and I have no idea if the faa radar sends out info on aircraft over the border.
In Canada you will only see mode c traffic if you are close enough to a us based ground station. In most of Canada you will see only other adsb. Out equipped traffic. Air to air. No weather here either unless close to a us station. I am installing a tail beacon in my rans s21. I use a trig tt22 for adsb outin my rv
Will a Garmin 796 see anything from a non-Garmin
ADS-B "IN" unit? I don't think so?
Ron
ADS-B TRAFFIC
Ron
''ADS-B "IN" unit? I don't think so?''
I should have been more clear I guess by stating that my friend see me on his 796 via a GDL-39-3D ADS-B IN device...:eek:
Bruno
Well I was hoping to see all traffic by installing an ADS-B OUT DEVICE but I guess I'll have to rely on my thrusty Monroy ATD-300 and my eagle eyes ;) to fill the gap.
Thank you all gentlemen for the info, it's appreciated.
Bruno
You will also see Mode S transponders.
ADS-B OUT TRAFFIC
Hi Rob
''You will also see Mode S transponders.''
Those must be the one I see without the Ident been displayed?
Bruno
