Old 02-04-2013, 09:39 AM
Stump's Avatar
Stump Stump is offline
Default #3 cylinder washer install
I am pursuing putting a washer behind #3 cylinder to help cool it down. I have Millenium cylinders. I have searched and cannot find a picture of where the screw is that attaches the baffles to the cylinder and therefore where the washer goes, of course maybe i can't do this with millenium cylinders, i don't know. I will post a pic of my baffle once i get to the hanger, but in the meantime, does anyone have a pic showing where this screw is?
thanks.
stump
Stump
RV-6A
Old 02-04-2013, 10:44 AM
crabandy crabandy is offline
I can't do a pic at the moment, but will be home 1:30 ish
Old 02-04-2013, 02:50 PM
Back of baffle behind cylinder 3, it's the screw just below the scat duct flange.
View from the top rear corner of baffling, look by the 470 rivet head and you'll see the washer between the baffle and the head.
Old 02-04-2013, 05:19 PM
Stump's Avatar
Default Thanks!
Thanks for the pic, that helps!
Stump
Stump
RV-6A
Old 02-05-2013, 10:01 AM
Stump's Avatar
Default Is this the right spot?
In looking at my baffle setup, it appears the hole indicated by the arrow has a corresponding screw hole on the side of the cylinder (Millennium). am i correct in thinking this is the hole talked about where people have attached the baffle to the cylinder with a washer on the cylinder side? I didn't build the plane and am enjoying the challenge figuring out what the builder did....
Stump
RV-6A
Old 02-05-2013, 10:12 AM
Yep, that looks like it.
As I recall, it is course thread.
Old 02-05-2013, 04:22 PM
Affirmative, that's the correct hole. I just did this last week, the screw is a MS35206-265 with a MS35333-39. It is smaller than the MS35206-281 by the rocker covers. A couple of open screw holes on my engine had to have a tap run through them to clean out some gunk before the screws went in correctly.
Old 02-05-2013, 04:42 PM
6 Gun 6 Gun is offline
Default Cooling
On our 6A when we got it we had cooling problems on #4 install air dams in inlet top cowling and had problems on #3 in the end found out wrong type leads under spark plug went to new in cylinder screw in type and right kind for gauge and things were better RV 6's are harder to cool.
Bob
Old 02-06-2013, 02:13 AM
PCHunt PCHunt is offline
Of course, everyone means "coarse" thread.
Or is it:
Of coarse, everyone means "course" thread.
Or:
Of coarse, everyone means coarse thread.
Or:
Of course, everyone means course thread.
Couldn't resist!
Old 02-06-2013, 08:28 AM
Oh curse, I didn't buy coarse thread!
