Go Back   VAF Forums > Main > RV Building Tips/Techniques
Old 11-01-2012, 07:11 AM
cfiidon's Avatar
cfiidon cfiidon is offline
Default Tip: Lower Cowl Installation by Yourself
I came up with this method of putting the lower cowl in place on my RV-8. Others have also supplied tips, but I wanted something that was small and lightweight to carry in the airplane. I envisioned having to replace the lower cowl on a windy ramp at night on an isolated ramp somewhere.
The pictures show using the "handles" from large binder clips to slip in the cowl hinges on the sides. The parachute cord simply loops over the baffling. I can inch the cowl up into place one side at a time without scraping it on the ground.
I bought the the rope and tension pieces in the Home Depot Aviation department. You could probably get away without that part if you are good at bowlines and slip knots.
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
Old 11-01-2012, 07:17 AM
Greg Arehart's Avatar
Greg Arehart Greg Arehart is offline
Really slick idea for the traveling tool bag.
Greg
Greg Arehart
RV-9B (Big tires) Tipup @AJZ or CYSQ
N 7965A
Old 11-01-2012, 04:56 PM
Rupester Rupester is offline
Default A nifty idea ....
...and thanks for sharing !!
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 09-05-2020, 02:54 PM
smithflys23 smithflys23 is offline
Don
Now that you can post pictures directly on VAF, would you please post some pictures of your device?
