POSTING RULES
Donate yearly (please).
Advertise in here!
Today's Posts
Insert Pics
04-04-2012, 06:51 PM
Fuel Filter Fuel Injection System
The fuel system for my RV-9A with a fuel injected IO-320 will have Andair GAS375 gascolators in the wing roots (Canadian regs, gotta have a gascolator or two) and an electric fuel boost pump in the usual place in the tunnel. The Andair gascolator filters are rated at 70 micron. The Precision Airmotive Silverhawk system requires a 32 micron filter upstream of the engine driven pump.
I have looked at all the inline filters (Flo Eze etc) and don't want to have a filter in the cabin and don't want to have a filter that I have to disconnect the lines to service the filter. Ideally I would like a Tee type filter mounted to the firewall in the engine compartment. After an extensive internet search, the closest I can find is an AN6234 filter. This is normally a hydraulic filter, and rated for 1500 psi, overkill I know but if it is satisfactory as a fuel filter it's a good possibility.
Has anyone used an AN6234 filter as a fuel filter on an injected engine? Can anyone recommend any other 32 micron Tee type fuel filter?
Terry Edwards
RV-9A (Fuselage)
2020/2021 VAF Contribution Sent
04-08-2012, 01:52 PM
32micron fuel filter
OK so nobody has used an AN6234 as a fuel filter.
Has anyone used a 32 micron fuel filter or gascolator that is not the FlowEze or Earl's inline style?
Terry Edwards
RV-9A (Fuselage)
04-08-2012, 05:17 PM
I'd like to see Don from AFP weigh in on this but...
AFP uses a 125 micron filter in their pump kit, this has been the standard for all of Van's FI systems, both Bendix and AFP. I went to a 74 micron filter just to gain a bit of extra filtering but was also cautious in the begining to make sure I did not have any pump cavitation as a result (I am using a Weldon for a back up pump in place of the AFP setup). In addition, the filter should be upstream of the pump to protect it from debris and cllogging.
Mounting the filter on the firewall also turns the filter into a nice big fat fuel heat sink, just ahead of the mechanical fuel pump, this is a bad combination.
I just cleaned my filter (which is located just after the selector) the other day, no big deal, minimal mess.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
04-16-2012, 07:33 AM
I am planning on using these filters, one in each wing root for my injected 360. They have over 14 sq inches of 100 micron SS mesh filter area and are very well made. Any reason not to, that I may have not considered?
http://www.ebay.com/itm/KRC-4706-6AN...item58905861fc
http://www.krcracing.com/ Better description in catalog.
Wade Lively
-8, Flying!
N100WL
IO-360A3B6D, WW 200RV
Reason: added catalog
04-16-2012, 08:13 AM
Another option from Flowezy is the 3000 series with 20 sq inches filtration area.
04-16-2012, 08:16 AM
looks like
thr kr filter in the second photo has hose clamp type fittings. Be sure to use AN-6 fittings. I have an extra filter that came with my Vans FI pump kit if you are interested. I used an Andair gascolater in place of the filter... Email me at fraziernv at gmail dot com.
Terry F.
RV 7A N457RV
250 hours and lovin it!
Southern Nevada EAA Chapter 1300 - www.eaa1300.org
Paid VAF 03/17
04-16-2012, 08:24 AM
Yes AN6 fittings, the first link.
I quoted 14 sq in off the top of my head, but the value I actually measured is higher, I just didn't want to be way off on the high side.
They are significantly less expensive than the FlowEzy.
Wade Lively
-8, Flying!
N100WL
04-16-2012, 09:50 AM
Fuel Filter
I have the Vans electric fuel pump and filter system forward of the fuel valve for my IO-320. Cleaned it last month. Had the same experience as Walt's post above "no big deal, minimal mess." As always, when fooling with fuel, keep ignition sources away.
Dan Burdette
Skyview, ADS-B, Garmin 420W, TT Gemini AP
RV-9A, IO-320, E-Mag
Guthrie-Edmond Rgnl, OK (KGOK)
________
03-03-2015, 06:07 AM
Old thread I know.
Which filtration level did you go with? I like that they offer a few choices. Does a 40 micron with that much surface area sound about right?
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
RV-44 : 4 place helicopter on order.
03-03-2015, 06:16 AM
Originally Posted by Geico266
Old thread I know.
I use the 74 micron.
