POSTING RULES
Donate yearly (please).
Advertise in here!
Today's Posts
Insert Pics
01-18-2012, 08:27 AM
Design for lifting/placing the lower cowl?
Does anyone have a design or idea about a combination dolly and lifting device that would allow easy lifting and positioning of the lower cowl?
Would tilt the cowl, lift, straighten out, position for securing, etc. and reverse for removal. Dolly feature would allow moving it around and out of the way.
I am building a tailwheel 7 and am currently fitting the cowl. I don't look forward to potentially scratching it or dropping on the hangar floor.
At this stage in the build my few remaining brain cell are fusing into one uncreative lump.... Hope someone has a design or pictures.
Appreciate any help.
Dick Sunderland
01-18-2012, 09:10 AM
something-
like a motorcyle lift would work. NOT as heavy duty or elaborate, but same idea.
Tom
Ridgeland, SC
01-18-2012, 09:26 AM
Regardless of what you come up with, keep a roll of blue painters tape around. Put a strip of tape on the top front of your gear leg fairings and some behind your spinner. These are the areas that you will rub your cowling when you are taking it off.
You can also use the tape to hold the rubber cowl inlet ramp strips back so you can easily slide the canopy up without having them catch on the ramp.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
01-18-2012, 10:16 AM
Don't worry about scratches. Those are going to be the least of your worries with the cowl.
When you start filling the pinholes, that will take care of most scratches too.
01-18-2012, 10:32 AM
I stuck a couple of strips of 2" wide blue masking tape on the bottom to avoid the worst scuffs. Even then, I found that the tape was barely scuffed by the time I was done. Once you clearance the aft bottom corners for the gear legs, I think you'll find that it'll stay put by itself, especially if you have the spinner back plate (or facsimile) in place. Also, the cowl is pretty light. I found it was pretty easy for me to slide it back and up by myself, sitting on the floor in front of the airplane. I used a loose ratchet strap around the lower cowl & engine to hold it during initial fitting. Once I got the aft cowl trimmed to the gear legs and firewall, I used clecos to fix it to the camloc plates (I'm using 1/4 turn fasteners instead of hinge).
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
960+ hours as of June 30, 2020. Where did the time go?
01-18-2012, 11:12 AM
My mom came up with something many years ago. Took her about 9 months to construct. Seriously, a device like you describe would probably be more difficult and expensive than it would be worth.
Patrick Kelley - Flagstaff, AZ
RV-6A N156PK - Flying too much to paint
RV-10 14MX(reserved) - Fuselage on gear
http://www.mykitlog.com/flion/
EAA Technical Counselor #5357
01-18-2012, 12:24 PM
Cowl Lift
A cheap plastic chair with arms works pretty good. Slide it back under the engine then go to one side and lift it up into place.
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
01-21-2012, 10:39 PM
Clive that?s awesome
01-21-2012, 11:03 PM
I think Kiwi's are just naturally born with ingenuity!!
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
