2 blade Hartzell's vs 3 blade MT
The flight test data I obtained in a HR2 was with 2 blade Hartzell's and the 3 blade MT propellers.
The HR2 had the "D" twist 2 blade Hartzell, and the owner already knew that at full throttle the aircraft slowed down by 3 mph when going from 2600 RPM to 2700 RPM.
We focused on full throttle performance at 5,000' for the Reno Air Races.
The 3 blade MT Rocket propeller (198-52 blade) was 2 mph faster, but had the same characteristics as the "D" twist 2 blade propeller.
The HR2 slowed down by 3 mph when we went from 2600 RPM to 2700 RPM.
The "J" twist 2 blade Hartzell gave the same performance as the 3 blade MT propeller.
Except, going from 2600 RPM to 2700 RPM, there was a 3 mph INCREASE in airspeed.
And going from 2700 RPM to 2800 RPM, there was another 6 mph increase in airspeed.
This was on a stock 260 hp Lyc. IO-540 engine.
From another source using a 330 hp Lyc. IO-540 engine, this Rocket pilot saw an airspeed decrease when going from 2600 RPM to 2700 RPM using a "J" twist Hartzell.
Sometimes there are no simple answers.
Jim Ayers
