Go Back   VAF Forums > Main > RV Building Tips/Techniques
Old 05-08-2006, 09:34 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Default Tip: Proseal....The Facts and the Fiction
Working with proseal is no big deal.....really. It continues to rate right up there with canopy cutting as a chore many builders seem to dread with a vague sense of impending doom......shadows of ill-defined personal perception overwhelming the clarity of knowledge and reality. Who starts these wild overblown horror stories? Overrated piffle. The stuff of wasted worry.
For years I worked with proseal, often daily and for weeks at a time. Even after many years of working with a material used in far more applications than just fuel tanks, I still had to attend 3 days of sealer school to satisfy customer requirements for training when I did a stint on the C-17 program. The cockpit and nose section of the giant cargo plane is produced in St. Louis. It is proseal that makes pressurization possible. It made some sense to retrain when assigned to the C-17 program because the enormous size of the pressure vessel demanded proseal be applied precisely and application requirements were somewhat different than the routine techniques we commonly employed on the F/A-18 Hornet. Interestingly, those persons skilled in icing a cake performed better with a filleting spoon than their polysulfide-challenged co-workers when requirements specified spreading proseal evenly over a surface without any interruptions or other defects. In the self-interest of limiting the mess to an absolute minimum and keeping my clothes unstained (rarely successful since I refused to wear an apron), I did manage to absorb a few helpful tricks over the years. Admittedly, most of the time I used a pneumatic Semco to apply the stuff, but the use of a Semco sealant gun does present a logistical nightmare for the average homebuilder because it can accept a dizzying array of accessories including various sized tubes, nozzles, spreaders, extentions and such. Last but not least, the stock of limited shelf life sealer was mixed daily and manually stuffed into appropriately sized tubes by the friendly folk working the neighborhood sealer crib, stamped with an expiration date, then distributed plantwide into dozens of stategically located 40 degree below zero freezers for shop use. That was the way things were done for decades until a new age of economic fashion swept the nation. Not too many years ago, the powers-that-be decided proseal mixing should be subcontracted out to distant strangers, layoff notices soon followed, and the proseal mix is now shipped in from afar and stored in new 80 degree below zero uberfreezers!
Fortunately for the RV builder, the job of sealing a bit easier with the introduction of this handy device, essentially a caulking gun. http://tinyurl.com/28gf9o I recommmend using one, if possible. Such a device sure beats using a common alternative a homebuilder has traditionally been reduced to using...a paper cup and a popsicle stick or tongue depressor. Still, the device is nice but not really an essential tool.
As for proseal itself, if you get the stuff on your clothes...forget it. Nothing out there will remove proseal without also discoloring your shirt or pants. I take that back. Methylene chloride will "sometimes" work (depending upon the fabric) but its dubious use is best served for a much more noble cause...to decaffinate coffee. Otherwise its just too toxic a chemical and not worth the risk to health from needless exposure. Prior to using proseal, rub some barrier cream or lotion into your skin to more easily remove the stuff from your hands after a sealing session. Wear a pair or two of latex gloves anyway. You can peel the first pair off as required.
When I assembled my leak free fuel tanks, I proceeded exactly as I would at work. There is no compelling reason to wallow around in wet sealer needlessly! I would commonly apply the proseal to the mating surfaces of the parts (called fay-sealing), 100% cleco the assembly together, then allow it set up somewhere between tack dry and full cure. That's it. Walk away. Upon returning to work the next day or even better....after the weekend, I would then remove every second or third cleco from the assembly, wet install and shoot the rivet, then repeat the process over and over again until all the rivets were set.
The above pre-digital pictures make a poor attempt to illustrate the procedure I used on my 6A fuel tanks. First, after roughing the local fay sealing surfaces with maroon scotchbrite and thorough cleaning with MEK, the ribs were fay sealed and secured to the skin by 100% clecoing into place. I insured adequate squeeze-out (smoothed into an uninterrupted fillet seal) existed around the ribs and skin (and previously installed stiffeners) without any voids whatsoever. Session complete. I felt no need to have extra sealer arbitrarily slopped all over the place as a sort of voodoo talisman employed to ward off leak demons. In my mind, excessive and weighty sealer needlessly laying about in perpetuity simply displaced that much more fuel the tanks would otherwise hold. A day or so later, the rivets were wet installed by first removing the clecoes from alternate holes. When all rivets were finally set and while I still had interior access, AND to further insure against leaks, using a Q-tip or a toothpick, I swirled a dollop of sealer around the shop head of each rivet to encapsulate it to its dimple. Next came attaching the rear baffle to the tank skin. As shown, I routinely 100% clecoed and clamped assemblies together. I then allowed the freshly (fay) sealed assembly to set up overnight before moving on to and completing the final riveting. This procedure greatly reduced mess and bother when I worked with wet proseal during this interesting phase of construction. Correctly applied, proseal is truly a tough and awesome material.
The photos below were were added on 01/07/09 to more clearly illustrate the procedures I outlined in the original posting. These are detail photographs of the RV-8 fuel tanks I assembled in January '07 following the exact same procedures. Filled with fuel for some months now and like my -6A flying since '05, no leaks have been detected.
As in all aspects of our personal construction experience, we should strive for perfection knowing we will never really achieve it. Prosealing need not be the nightmare scenario some would have you believe. Far from it. There are more pleasant sheet metal tasks to do...sure...but...whoever said building an airplane was not going to be a challenging experience from time to time?
Rick Galati RV-6A "Darla" 124 hours
Last edited by Rick6a : 03-04-2009 at 08:06 AM. Reason: Added more recently assembled RV8 fuel tank and detail photos
Old 05-08-2006, 09:54 AM
TShort TShort is offline
When you say "wet installed" what do you mean? Did you cover the rivet in proseal before putting it into the hole?
Any problems with fitting the rivets into the hole once the clecoes come out? i.e. proseal in the dimple or in the hole?
Thomas
-8 wings - close to tank time
Old 05-08-2006, 10:31 AM
cjensen's Avatar
cjensen cjensen is offline
I have the exact same question Thomas...I started my tanks over the weekend.
Chad Jensen
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 05-08-2006, 10:55 AM
tomcostanza tomcostanza is offline
Default Now you tell me!!
Hey Rick! That information would have been a lot more valuable 6 months ago, but I'll know better for the next plane I build.
The problem I have as a newbie is not knowing what it looks like when it's done, and done well. It's like the Star Trek pilot show, where the aliens with the big heads re-assembled the human woman without knowing what one looked like. She worked OK, but she wasn't pretty.
I used too much Proseal, because I figured it would be better to have a tank that was slightly heavy, than one that was slightly leaky. Next time I'll know.
Thanks for the great tutorial.
Tom Costanza
-7A Fuse
Old 05-08-2006, 12:01 PM
For me, personally, I went the Orndorff method. That is "ProSeal is cheap, use a lot of it."
So I did. I run the bead along the ribs (as Van's also recommends, by the way) and I put a dab on each rivet head. If there was any doubt, I covered it in ProSeal.
It's possible, I suppose to have used less....but I kept hearing George's voice : "if you look in there and say to yourself, 'this can't possibly leak, it wont. And if you look in there and say 'I hope that spot doesn't leak, it probably will.'"
My goal at the time was to make sure it didn't leak. And, yeah, I did sacrifice some of the interior beauty of my tanks.
But I agree, the dread over ProSealing is much ado about nothing. I really enjoyed building the tanks.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
N612EF Builder log (EAA Builder log)
Old 05-08-2006, 12:23 PM
Rick6a's Avatar
Any problems with fitting the rivets into the hole once the clecoes come out? i.e. proseal in the dimple or in the hole?Thomas-8 wings - close to tank time
Tom,
"Wet installing" simply means to dab the countersink (most commonly with a Q-tip) with proseal before inserting the rivet. The idea is to seal the area under the head of the rivet. If any proseal migrates into the hole...all the better. Don't worry in the least about clecos sticking to the holes after the proseal has set up. They will come out just fine and as a bonus, clecos with a bit of sealer stuck to them tend to grip future holes that much better. Of course there are limits....limits you and I will never see. In the production environment, clecos used with proseal daily can over time build up so much sealer on them that they become difficult to work with and the only practical method cleaning them is periodic immersion in industrial sized ultrasound machines. They come out pin clean and none the worse for wear.
Rick
Old 05-08-2006, 01:41 PM
rv8ch's Avatar
rv8ch rv8ch is offline
Default Proseal
Kind of makes me wish I didn't have QB wings!
Want to write an article like that about fiberglass?
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 05-08-2006, 04:34 PM
b17fe's Avatar
b17fe b17fe is offline
Mickey,
Try this link From Jim Andrews site for your fiberglass woes.
http://www.rvpilot.com/Fiberglass/fiberglass.html
Steve
Old 05-08-2006, 05:58 PM
TSwezey TSwezey is offline
I don't know what everybody is complaining about with the Prosealing the tanks! Anyplace two pieces of metal come together on our airplane there is proseal. We did it to help stop corrosion which is a big problem in the Savannah area. I also think we could lose 90% of our rivets and the plane would stay together.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 05-08-2006, 08:41 PM
N916K's Avatar
N916K N916K is offline
Great tips for using Proseal. I used the cover it all with proseal method the first time. This next set of tanks will get your method, seems a lot cleaner. One thing, how set can I let the proseal get and still be able to rivet?
Cam
Santa Ana, CA
RV-9 at KFUL
