What is the best lube to use in the tach cable? Tim
Walt Well Known Member Apr 21, 2011 #2 tclaire said: What is the best lube to use in the tach cable? Tim Click to expand... Dry Graphite
V Vlad Well Known Member Apr 21, 2011 #3 Walt said: Dry Graphite Click to expand... Walt what is the best (less messy) method to put that dry lubricant in? Without disassembling of course. There is some sort of grease in there.
Walt Well Known Member Apr 21, 2011 #4 Vlad said: Walt what is the best (less messy) method to put that dry lubricant in? Without disassembling of course. There is some sort of grease in there. Click to expand... Hmm... Graphite is messy no matter what, pull the cable out wipe it down with a rag and start feeding it back in while adding the powder to the cable between your fingers. Not nearly as bad as pro-seal
