Go Back   VAF Forums > Main > RV Building Tips/Techniques
Old 02-09-2011, 03:00 PM
mike newall's Avatar
Default Tip: A New Take On De Burring
OK,
We all know that part of the 51% we have to do is the labor intensive, time consuming stuff.
Well, this came via a very experienced Engineer who has worked all sorts of metal for years.
To quickly de burr sheet you have drilled, consider this.
400 grit wrapped round a small tungsten bucking bar - light passes, putting pressure on just rips the paper.
Up and down the line of holes and feel afterwards.
Tried it on my empennage and was impressed. Compared it under a 10x lupe to a standard 3 flute twizzle de burring tool and quite frankly it was a lot better and cleaner !
Discuss
Old 02-09-2011, 03:06 PM
Question Hmmmm
I wonder if this is an "approved" thing to do to alcald??
Old 02-09-2011, 03:52 PM
It's only 400 paper - pretty much what you would use for edge prep.
Also, with the backing of the tungsten bar it really only cuts the edges of the holes.
As I say - only light pressure is needed.
You get very slight scruffing at the edges but no more than you would with - say red Scotchbrite.
Having seen the difference under a 10x glass, I am happy this leaves a cleaner edge much quicker.
Mike
Old 02-09-2011, 04:26 PM
lorne green lorne green is offline
Default deburring 101
If that technique is faster than conventional, go for it....but. For me; I would like to see all of the swirl marks removed from the surface of the Alclad with a
maroon scotch-brite pad. As you say, these marks are light so five or six passes with the pad should clean these up nicely. We want to leave the surface as "satin" a finish
as possible..stress risers are not our friend!
Regards
Lorne
RV 7a tip-up
Pre-cover MD-RA Inspected.
Canopy completed. Bonded with Sika-Flex.
Up on her mains, Firewall Fwd and wiring on going.
Old 02-09-2011, 11:30 PM
SHIPCHIEF SHIPCHIEF is offline
I'm worried that too much deburring is going on around here;
My 'Standard Aircraft Handbook' 5th edition, page 54:
...deburring..must be performed if the burrs tend to cause a separation between the parts being riveted. Burrs under either head of a rivet do not, in general, result in unacceptable riveting. The burrs do not have to be removed if the material is to used immediately; however, sharp burrs must be removed if the material is to be stored or stacked, to prevent scratching adjacent parts or injury to personnel.
Care must be taken to limit the amount of metal removed when burrs are removed. Removal of any appreciable amount of material from the edge of the rivet hole will result in a rivet joint of lowered strength. Deburring shall not be performed on predrilled holes that are to be subsequently form countersunk
For myself, I deburr lightly, or wipe off burrs with leather gloved hand or scotchbrite etc.
The 400 grit - on - bar looks like a safe way, but might not be acceptable if a polished surface is required later?
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
Old 02-10-2011, 02:13 AM
I would agree there !
If I let my Bro loose with the de burring tool, we had countersinks !
The old, single hole tool was OK, the 3 flute tends to be a bit harsh.
If you are contemplating polishing - this would be a no no, however I am pleased it is generating some discussion.
Old 02-10-2011, 02:50 AM
hendrik hendrik is offline
I started with Avery's 3-flute tool, but now I mostly find myself using a scotch brite pad. Much faster and better holes. There is probably little difference between the scotch brite and 400 paper for this application.
Hendrik
Club-Libelle: flying
RV-8: on hold (new job , new home , no workshop (yet) )
Old 02-10-2011, 07:10 AM
RV7Ron's Avatar
RV7Ron RV7Ron is offline
Couldn't agree more, deburring is WAY overdone in the RV world.
Ron Duren
Mechanical Engineer
"SportAir PhD"-RV Assembly/Composites/Electrical
Denver, CO (KBJC)
RV-7 'Tip Up'
Flying!! as of 3/16/14
IO-375/WW 200G-CS/SkyView/Dual P-mags
N531R "Wablosa" Wings of Red
http://www.ronsrv7project.blogspot.com
Old 02-21-2011, 06:42 PM
Marc Bourget Marc Bourget is offline
Smile
Folks,
Vans Kit builders have the convenience of rivet holes punched by a Trumpmatic CNC machine. AC43-13 references deburring rivet holes with a deburring tool or oversized drill. I believe simply sanding the skin will not achieve the desired results because a perfectly square hole edge still constitutes a stress concentration.
A very slight bevel, even if a few thousanth's is preferable. Having experienced crack formation upon dimpling (guess where my opinion on the necessity of deburring with a drill was reinforced?) with holes I forgot to debur, (and never experienced with holes I did debur), I'm an advocate of deburring with a drill. I use a dedicated, new drill, that I installed in a file handle. No weight, simply the weight of the drill, lightly spun by hand - about 1-1/2 turns.
For holes added by the builder, careful drilling technique is required. Make sure you're "normal" (90 deg) to the skin, Consider using a "spotter" to insure your vertical. Slow down when you're about to "punch through" so as to minimize burr size.
I'll be repeating my Aircraft sheet metal seminars at Sun'nFun and I am scheduled for Airventure if any novices or inexperienced are interested. I won't presume that I can aid, or change the minds of the experienced!
Onward and upward
Marc Bourget
TC#5436
Old 02-22-2011, 02:38 PM
704CH's Avatar
704CH 704CH is offline
Might work for some, but I will continue to debur the old fashioned way. I like my skins looking clean on the outside surfaces, and then scotch-brite pads before prep and priming on the inside..
I like building and don't mind the extra time involved with a simple single twist of the debur bit in every hole. Tried and true, and looks good.
After two years into this project I don't know what I am going to do with myself when it is finished.. Build another I guess. ;-)
Thx
Chad
Sammamish, WA
RV-7 Standard Build - Tip UP
Flying ! As of 032913
Superior IO-375, WW200RV, Single Lightspeed, SkyView, GTN
http://www.704ch.com/
