Old 10-17-2010, 09:15 PM
marchudson's Avatar
marchudson marchudson is offline
Default Running out of ideas
On how to fix the problem with RFI/EMI.
Components that I have:
GNS430W (Comm 1)
SL-40 (Comm 2)
RG-400 coax cable
2 - RAMI bent whip antennas mounted on belly
Dynon Skyview with EMS module
Single point ground for everything.
Problem I'm having:
When I transmit on comm 1 AND comm 2, the EMS readings go nuts. CHT/EGT moves anywhere from 10 deg to 100 deg depending on the frequency that I'm transmitting. If transmitting on 118.0 I'll get just a little change, on 136.0, I get a huge change. When transmitting on 124.0, the ammeter goes from +8 amps (normal) to -35 amps. Talked to the Dynon folks and they said that I'm the only one with this problem?????
Solutions I've tried:
1. Replacing both cables with store bought cables and routed them in random locations to see if this makes a difference. (no difference noted)
2. Power the Dynon with just the standby battery (no difference). Note Dynon system is still tied to aircraft ground system.
3. Disconnect the sensor wires from the EMS. result - system behaves normally but I don't have any engine monitor readings either. (Maybe noise is not entering EMS module on power supply lines)
4. Place a 12" X 12" piece of aluminum foil on the antenna, touching nothing else but the antenna. (normal indications - I deduce by this that the coax is probably not leaking due to this, don't know)
5. Transmit on Comm 1 and compared results to transmitting on Comm 2. Both radios produce the same adverse results on the EMS.
My next step is to place ferrite chokes on the 3 EMS cables. But is this just putting a bandaid on the problem? I would rather fix the root problem.
OK... I'm open for suggestions. Do I need to purchase a SWR meter or purchase a different brand antenna?
Thanks for your time
Marc Hudson
Houston
RV-7 Sold
Old 10-17-2010, 09:37 PM
Norman CYYJ Norman CYYJ is offline
Make sure that the antennae are properly grounded to the airframe. The base of the antennae need to be bonded where they are mounted. It does sound as though you have extremely high VSWR and a poorly grounded antenna can do this. Good luck.
Old 10-17-2010, 11:32 PM
AltonD's Avatar
AltonD AltonD is offline
Grounds. Make sure you have a very good ground from all components, including the engine. Did you use a ground block or are your components grounded via the frame?
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 10-17-2010, 11:47 PM
scsmith scsmith is offline
Default antenna ground
I agree, its the first thing I thought of. The antenna is not grounded at its mount, and/or the shield braid of the RG-400 is not grounded to the connector(s).
Try leaving the engine thermocouples connected to the Dynon, but not plugged into their spots on the engine. So the probes are just hanging in the air. That way, the probes can not pick up any ground noise. If they still act up, the noise is coming in through the power and ground leads to the Dynon. If they are quiet, you know the noise is coming into the probes. Either way, you are putting a lot of energy into the ground somewhere.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 10-18-2010, 06:05 AM
marchudson's Avatar
Default Grounds
Thanks for the quick replies guys. My initial thought was also the ground. My first action was to check the continuity of both antenna bases to the airframe and I am getting zero resistance. The engine is grounded to the airframe via a #2 welding cable and I checked the resistance from several locations on the engine to the grounding block, zero ohms. As far as the coax shield grounding is concerned, I checked both with the meter and then removed them from the equation when I temporarily replaced them with store bought RG-58 cables.
Steve - I actually tried your idea of unplugging a few of the CHT probes from the engine. When they are left near the engine but not touching anything I get the same results. If I let the probes dangle below and very near the main gear, the problem gets much worse. I figured that they are in the direct path of the radiated energy when dangling.
Alton - yes I have a single point ground for all equipment in the aircraft and everything is running to it.
Sounds like guys think I might need to get an SWR meter to determine the health of the antenna / cable combination.
Marc Hudson
Houston
RV-7 Sold
Old 10-18-2010, 07:21 AM
R.P.Ping R.P.Ping is offline
Default Bounce back
I had some initial problems when I was checking systems out in my garage. Just couldn?t get the led lights not to glow when I transmitted. Checked grounds, moved antenna wires, checked antenna connections. Ended up it was the signal bouncing around inside the garage. All my work trouble shooting was for nothing. If you can move your project outside it will probably work just fine.
Roger Ping
KDVT Phoenix Deer Valley
RV-9, O-320, 160HP, C/S
Old 10-18-2010, 07:25 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Have you checked with Dynon on this? I have had two builders talk to me about RFI and their Skyviews. Both were working with Dynon to solve the problem, with varying results. This might be a case of new hardware (the Sky view is still pretty young) going through some early learning stages.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 10-18-2010, 07:31 AM
Mel's Avatar
Mel Mel is offline
Marc, I believe you are located at Caddo Mills. If this is the case, I have an SWR meter that you may borrow. I'm at ShortStop Airfield less than 10 miles north of you.
972-784-7544
Mel Asberry, DAR since the last century.
EAA Flight Advisor/Tech Counselor, Friend of the RV-1
Recipient of Tony Bingelis Award and Wright Brothers Master Pilot Award
USAF Vet, High School RV-12 Project Mentor.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 10-18-2010, 07:48 AM
rich rich is offline
Default RF/EMI
I had the same problem with my SL-40 and RMI eng. monitor.
When I would transmit the RMI CHT/EGT readings would go nuts and set off alarms.
Take a hand held com and while transmiting run it up and down your wire bundles and observe your EMS. When the numbers start to change you found a "LEAK" where RF can enter. I found my worst leak where the CHT/EGT'S connect to a rotary switch . I wrapped some braided shielding around the area so at least the alarms don't go off now.
I too have everything grounded to a grounding block on the firewall.
If you find the "FIX" let me know.
Good luck,
Rich Rudolph
VAF#007
RV6A 2000 HRS.
Fort Worth,Tx.
Wright Brothers “Master Pilot” Award
Old 10-18-2010, 01:40 PM
kalaharikid kalaharikid is offline
I had the same problem with my SL30. Vans gauges and the LED indicators for flaps and trim went crazy when I transmitted. Two things changed - I moved the plane to the airport (and out of the garage) and painted it. One or the other or both are the only factors that changed and the problem went away. I also spent many hours checking grounds etc. to no avail.
Gary Keyser
RV-7 Sold
RV-9A QB Finishing
