POSTING RULES
Donate yearly (please).
Advertise in here!
Today's Posts
Insert Pics
09-21-2010, 11:48 AM
I am ok with those semantics:
“We are not looking to replace a defective nosewheel design, or replace it for everyone, we are looking to provide a more robust option for less than ideal terrain for those that may wish to have it.”
Rick from Fresno
RV-7A
The art to flying lies in learning how to throw yourself at the ground and miss.
09-21-2010, 12:41 PM
UK nose gear design
Here is one we have designed in the UK. It needs testing and I am willing to do that on my RV9, but I need an undrilled nose wheel spring as I dont want to cut my own in case we have to revert to the old set up. If anyone has a spring available let me know.
http://img243.imageshack.us/img243/1809/27012010311.jpg
09-21-2010, 01:01 PM
I'm in
I will vote with my money if Vans will not take this on. I would prefer however that Vans take on the job and suspect that they may already be doing this. To be realistic how could Van's acknowledge a problem without risking liability? I would not expect them to do so. They may however come out with a new design as has been my past experience.
When I asked about the new gear leg on my 7-A, and if I could replace it with the new one with better ground clearance, I was told by Vans that this was not really a problem. The profile of the wheel and wheel pant remained the same. The new designed fork was only a weight saving improvement thing. Later they came out with the suggested fix.
The wheel pant profile argument is that the wheel pant has to be destroyed before the nut can dig into the ground and be a factor. But this is exactly what was, and still is happening, even with the new fork. To me it appears that the nose wheel is already starting to tuck under to allow the wheel pant to be destroyed and for the nut to start digging in. The gear at that point has flexed too far already. If you do not think this is a problem that is your prerogative. Have you not watched the post-game films? I think that the evidence is that the pole vault pilots were and are good pilots. It is not the case of botched landings or needing more training. I feel that I am susceptible to joining those of the pole vaulting club with the existing gear leg.
New builders deserve better. I do not consider myself a timid person, but like some others here, I will not land on grass in my RV-7A. I fly my Citabria in the mountains and land the back strips, but can not bring myself to land on a grass strip with the 7A without having walked it first. The trust is not there. I think I am being a smart pilot to follow my instincts. They have served me pretty well so far. Keep off the grass.
Count me in for support for a better design. I think we need it. Meanwhile expect me to only land on paved runways, or look for me to be converting to tail wheel after I get inverted oil installed, and a smoke system put in. I am catching up on my projects again.
RV-7A - Flying
09-21-2010, 01:17 PM
Same here, I'll vote with my checkbook. I'm not looking for a "fix", I'm looking for an "unimproved runway nosegear option".
Greg Niehues - SEL, IFR, Repairman Cert.
Garden City, TX VAF 2020 dues paid
N16GN flying 700 hrs and counting; IO360, SDS, WWRV200, Dynon HDX, 430W
Built an off-plan RV9A with too much fuel and too much HP. Should drop dead any minute now.
09-21-2010, 01:19 PM
I dont really have a horse in this race as I'm building a -7. But as an Engineer, I think Van's designed the nose gear for the mission of the aircraft. (Keep in mind, I have not done any Engineering analysis of the design and my opinions are based on just visual inspection of the design) Its a cost effective, lightweight sport aircraft and is not specifically designed for operating out of rough strips. If I'm the design Engineer and I have that mission criteria I probably would have come up with something very similar to what Van's did. From the reports I have read, I dont think it is a problem for the mission it is intended for. No disrespect to those that do, thats just my .02
Keep in mind, with any design, there are trade-offs. You can beef up the nose gear--maybe with more expensive/exotic materials and/or adding weight. Whats the trade-off? Its more expensive and/or weighs more.
That leads to reduced performance and less useful load. Although I dont design aircraft I know that with aircraft design, the trade-offs are extremely important to accomplish the mission goals. Will you as the owner accept less useful load (less baggage? less fuel?) or a more expensive airframe for a stronger nose gear? Maybe this would be ok for some but certainly not for others. You cant make everyone happy, this aircraft may not be perfect but it fills most 'wants and desires' of its owners.
With all that being said, I havent seen a 'perfect' design yet...I always like to think there are ways to improve with enough imagination. Could someone come up with a stronger nose gear design without adding weight, complexity or cost? Maybe?...maybe not? Its not easy. Just understand what you're up against if you hire someone. An independent Engineer may come to the conclusion that he cant do it any better...thats a real possibility.
Ron Duren
Mechanical Engineer
"SportAir PhD"-RV Assembly/Composites/Electrical
Denver, CO (KBJC)
RV-7 'Tip Up'
Flying!! as of 3/16/14
IO-375/ WW 200G-CS/ SkyView/ Dual P-mags
N531R "Wablosa" Wings of Red
http://www.ronsrv7project.blogspot.com
09-21-2010, 01:58 PM
Perhaps another possible solution to this problem rather than a stronger gear would be one that fails in a safer mode. If when the nose gear collapses rather than acting as a spring board flipping the airplane over on its back, it would simply break off, that would be a much safer scenario. The plane in many instances would simply end up embarrassingly on its mains with its nose in the dirt, a bent prop and probably a damaged engine but at least the airplane would not be a total loss and the occupants would not be trapped in the wreckage, possibly requiring medical attention or worse.
Joe Condon
Ankeny, Iowa
RV9A - 647JC - 300 hrs - SOLD 6/23/15
OneX - Under Construction - For Sale
09-21-2010, 02:54 PM
I would agree with this except Van designed it and demonstrated it many times on his home field, which I understand is a short, grass strip. It's even been said that the -A models are better short field performers because they can rotate to a higher AOA on landing without smacking the tail... Although I don't know if that was a Van's position or just some other person's opinion.
Rob Prior
09-21-2010, 03:03 PM
I have been keeping close attention to these threads, and was pretty interested.
Where I am building my -12, there is a -6A next door that i take a look pretty often. One of the things I noticed is that the RV-12 has a much more 'robust' nose gear/wheel.
Perhaps the -12 gear could be looked into as a low-cost alternative, or at least a situation where the engineering has already been done, and can be used to modify the A models?
RV-12: 331RV
Started 3/31/10
First Flight: 4/2/11
09-21-2010, 03:33 PM
I've heard that some people have solved the problem by taking the nose wheel and putting it on the tail of the airplane. Could you imagine? That's just CRAZINESS!!!
I'm so sorry! I just couldn't resist! It's my duty as a tailwheel driver... Can someone please forgive me?
- Peter
Peter Fruehling
St. Paul, Minnesota - Based at ANE
RV-4 - Sold
RV-7 - Sold
RV-10 - Partners in N829EC
2019 Dues Paid - Have you paid yours?
09-21-2010, 03:44 PM
I agree also... 10's of 1000's of landings with "A" models have been performed on grass strips, it happens everyday. And, no the "A" model RV's is not for just any flyer/pilot. And, yes if you make the decision to land on a very rough un-maintained grass strip well YOU made that decision. The gear as designed works and functions well. Can it be heavier and made super beefy? Well yes. Not for me.
I will also hint this... Jack your "A" model plane up and totally level the plane... all axis perfect level flight about 2 inches off the floor. Then with the nose fairing off the plane, take a digital level and check your nose wheel and fork dead straight and centered on both sides. I'm interested in hearing some results. Mine is fixed now. There may be an issue, but I not blaming it on the nose gear leg.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
