Old 05-27-2010, 05:00 PM
benamyava's Avatar
benamyava benamyava is offline
Default Round dial panels demise is official
ADS-B Equipment Required in Next Decade
Notice Number: NOTC2314
New Automatic Dependent Surveillance ? Broadcast (ADS-B) Rule
On May 27, 2010, the FAA published new rules (contained in 14 CFR ?92.225 and ?91.227) mandating airspace and avionics performance requirements after January 1, 2020. The avionics perform a function that is generally known as ?ADS-B Out? which transmits precise location and other information about the aircraft to ground stations and other ADS-B equipped aircraft.
The ADS-B rule mandates ADS-B Out avionics performance when operating within the designated airspace, giving aircraft owners approximately 10 years to equip.
The ADS-B rule, like current transponder operating requirements, requires operators to have ADS-B Out avionics installed and operating in order to fly their aircraft in the busiest airspace, as described below:
Class A, B, and C airspace.
All airspace at and above 10,000 feet MSL (mean sea level) over the 48 contiguous United States and the District of Columbia.
Within 30 nautical miles of airports listed in 14 CFR ?91.225, from the surface up to 10,000 feet MSL.
Class E airspace over the Gulf of Mexico from the coastline of the United States out to 12 nautical miles, at and above 3,000 feet MSL.
FAA Technical Service Orders (TSOs) describe the equipment approved for ADS-B operations. The ADS-B rule states that avionics must meet the standards of either TSO-C166b (for 1090ES link equipment) or TSO-C154c (for UAT link equipment). TSO-C166b is required in Class A airspace and either link can be used in all other airspace.
For more information about the FAA?s ADS-B program, visit www.adsb.gov.
Questions?
Contact the FAA Flight Standards ADS-B Office at: 9-AWA-AVS-ADS-Programs-AFS@faa.gov.
Contact the FAA Aircraft Certification ADS-B Office at: 9-AWA-AVS-ADS-Programs-AIR@faa.gov.
This notice is being sent to you because you selected "General Information" in your preferences on FAASafety.gov. If you wish to adjust your selections, log into https://www.faasafety.gov/Users/pub/preferences.aspx where you can update your preferences.
The new WINGS?Pilot Proficiency Program is great! Check it out now!
Old 05-27-2010, 05:06 PM
mculver's Avatar
mculver mculver is offline
Direct link to the entire doc: http://www.federalregister.gov/OFRUp...0-12645_PI.pdf
-- Mike Culver;
RV-9 project sold but details of the build at
www.mculver.com
Old 05-27-2010, 07:56 PM
rzbill's Avatar
rzbill rzbill is offline
Default All fine and good BUT...
I would put Navworks in TODAY (and I might still ) if I didn't already spend MORE on a &^#%!!! transponder!
Since the ADS-B out provides the data needed to ATC to perform what is done now with transponders, one would ASSUME that transponders will become a thing of the past. I have not heard one peep about when THAT date is to occur. I imagine I will be dead and buried before we don't have to carry both on the panel.
I actually couldn't care less about ADS-B "out". ADS-B "in" is what will help me in the cockpit.
Bill Pendergrass
ME/AE '82
RV-7A: Flying since April 15, 2012. 850 hrs
YIO-360-M1B, mags, CS, GRT EX and WS H1s & A/P, Navworx
Unpainted, polished....kinda'... Eyeballin' vinyl really hard.
Yeah. The boss got a Silhouette Cameo 4 Xmas 2019.
Old 05-27-2010, 08:15 PM
N395V's Avatar
N395V N395V is offline
In January 2020 I will once again be wearing diapers and eating baby food.
Milt Concannon
Old 05-27-2010, 08:27 PM
gvgoff99's Avatar
gvgoff99 gvgoff99 is offline
I agree, NavWorx agrees ....however...... the problem seems to be that some passive aggressive type in the FAA has the ADS-B "out" feature shut off to people with ADS-B "in" unless the ground station first detects an ADS-B "out" signal. If there is a plane in the area that has ADS-B "out" then the "in" signal can be received by everyone in the area where the "out" signal is detected. But the "in" only receiver will only get a "in" signal to use if there is an "out" guy in the area.
There are people with some common safety sense, that are fighting this but for the time being both are needed for reliable reception.
This may be a mute point, for the most part, in areas where there are commercial guys in the air.
Even so: Pretty sad!
George Goff RV-6A (Flying 3/7/2006 )(Houston, TX)
Old 05-27-2010, 08:53 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
This has ZERO tie to round/steam gauges. I am adamantly opposed to this mandate since it buys me NADA....except an expense. Maybe you get an APRS like trail...if you fly where there is coverage.
Old 05-28-2010, 10:58 AM
benamyava's Avatar
The myth of ADS-B "out" providing only current mode C transponder data is false. ADS-B's current and planned CNS capabilities are far more extensive. Round dial electromechanical instruments do not have ARNIC 429/729 capabilities and will not be able to provide the data parameters needed.
Old 05-28-2010, 11:09 AM
Ron Lee's Avatar
CNS is communications/navigation/surveillance
ADS-B Out provides GPS/WAAS generated position/aircraft ID data to appropriate receiver systems on the ground and in the air.
Whether I have steam gauges is irrelevant. You do not need a glass panel from my understanding. If I am wrong then that ups the cost a lot.
Back to CNS. ADS-B Out is a one way system. It sends position data. It receives nada from the ground. It does not provide the pilot nav info. Thus in my opinion it is only a surveillance type system.
The benefit is to the FAA...not the GA pilot. See my detailed view here
http://stopads-b.org/ADS.htm
Old 05-28-2010, 02:41 PM
benamyava's Avatar
The PFD is the heart of an ADS-B cockpit. ADS-B technology is not another transponder "box" we currently use. The PFD will be the processor which relays all AIRNC 429 bus data out to the 1090 Mhz squinter piggy backed on the Mode S transponder signal.
ADS-B "out" information is not only going to transmit the current position of the equipped aircraft but also its "intentions." The "intentions" will be connected via the AIRNC 429/729 bus. The DEAL BREAKING INFO required is not the position of the aircraft but its intentions in the form of the flight plan loaded into the GPS or the current mode control panel settings of the lateral mode and vertical mode.
The old concept called "Free Flight?" has matured into Autonomous Flight Rules (AFR). AFR embodies the benefits of ADS-B.
AFR is where this is all headed. ADS-B "out" is required for AFR operations to be allowed to operate "autonomously" while maintaining their surveillance and ensuring their separation in the system.
Old 05-28-2010, 08:06 PM
N200PF's Avatar
N200PF N200PF is offline
This is GREAT NEWS for those of us that are interested in flight safety. ...and ADS-B without an equipment mandate would hold little value. If you can't see everyone what's the point?
I can only imagine what Garmin's going to charge to upgrade the 900X. That will be fun.
- Peter
Peter Fruehling
St. Paul, Minnesota - Based at ANE
RV-4 - Sold
RV-7 - Sold
RV-10 - Partners in N829EC
2019 Dues Paid - Have you paid yours?
