Old 11-24-2009, 12:25 PM
Brantel's Avatar
Brantel Brantel is offline
Default RV-7 Tipups...Getting in and out easier?
Up until I moved my craft to the hangar, I always either had the tail up on something, had the canopy removed and or did not have the wings on.
Now that the wings are on, the tail is on the ground and the canopy is on, I find that on the taildragger, the canopy does not open far enough to make it easy to get in and out without putting some serious weight on the roll bar since the person getting in and out is off balance.
Has anyone noticed this but me? Anyone got any ideas to make this better?
It would be nice if the struts would allow the canopy to go more vertical but this would mean different struts and or anchor points that start getting in the way.
Is there such a thing as a telescoping strut with the same load capability?
Brantel (Brian Chesteen),
Check out my RV-10 builder's BLOG
RV-10, #41942, N?????, Project Sold
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 11-24-2009, 12:50 PM
sprucemoose's Avatar
sprucemoose sprucemoose is offline
Getting in and out does require leaning on the rollbar. The rollbar is a pretty beefy structure; it can take the weight of the airplane upside down, so it can certainly handle a person leaning against it.
If you are trying to get in and out without putting any pressure on the rollbar, that would be pretty difficult, but it isn't neccesary.
Jeff Point
RV-6, RLU-1 built & flying
Tech Counselor, Flight Advisor & President, EAA Chapter 18
Milwaukee
Old 11-24-2009, 01:00 PM
I don't think the rollbar would be a problem. I think the problem would be if there's significant weight on that crosspiece below it (behind the seatbacks). One of the things I learned when Tom Berge looked over my project this summer is that doing so will bend the vertical piece -- the aft portion of the flag mechanism enclosure. And that makes sense. There ain't a lot of beef in that piece but getting out is where I think things get problematic. You don't want to put weight on that and obviously you don't on the armrest, either.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
N612EF Builder log (EAA Builder log)
Old 11-24-2009, 01:06 PM
Brantel's Avatar
Bob,
If you have the flap box enclosed with the screws in the side covers, it would take a huge load to bend that seatback brace....
Now if you don't have the sides on or the diagonal brace, thats a different story.
Old 11-24-2009, 01:07 PM
JDRhodes JDRhodes is offline
Default tipper problems - there is a solution!
OK - I'll be the guy that says it - A slider canopy eliminates this problem!
Actually, we have both in our hangar: a tipper -7 and a slider-9. You're right, the tipper canopy on the tailwheel gear does make it difficult. I like the slider better, for that - and other - reasons.
Jeff Rhodes - Taylorsville, GA
RV-9, 7 - going fast
BC-12D - going slow
jrhodes@v1salesmgt.com
Old 11-24-2009, 01:12 PM
Brantel's Avatar
I don't buy that one...I have more time in a slider 7 than a tip up. The slider has it's own set of problems....
Like, you cannot put any weight on the open canopy behind you.
You have to be carefull and not pull/push on the lip around the front windshield.
It does have complete openness once you get stood up in the seat though which helps some.
Its the lean on the TD's that cause the issue for me.
Actually, we have both in our hangar: a tipper -7 and a slider-9. You're right, the tipper canopy on the taiwheel gear does make it difficult. I like the slider better, for that - and other - reasons.
Don Jones's Avatar
Don Jones Don Jones is offline
Default or.....
.....a nosegear
Don Jones
Technical Support Manager
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
Old 11-24-2009, 01:15 PM
Brantel's Avatar
But then I would rob myself of the pleasures of TD flying and those occasional moments of shear terror!
Originally Posted by Don Jones View Post
.....a nosegear
Old 11-24-2009, 01:41 PM
Mel's Avatar
Mel Mel is online now
A big part of this particular problem is the struts themselves. I never liked them and never installed them. I also have removed them from several customer's airplanes.
The other problem with the struts is that they defeat the canopy jettison feature.
Never had a problem getting in and out, even at my age!
Wouldn't trade for all the sliders in the world; but that's just me.
Mel Asberry, DAR since the last century.
EAA Flight Advisor/Tech Counselor, Friend of the RV-1
Recipient of Tony Bingelis Award and Wright Brothers Master Pilot Award
USAF Vet, High School E-LSA Project Mentor.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-24-2009, 02:10 PM
.....a nosegear
...or a Cessna. Hmmm - the world is full of comprimises!
I've never really been afraid of using the tipper rollover structure to assist in getting in / out. It's pretty stout.
BC-12D - going slow
