Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 11-18-2009, 08:09 AM
jeff beckley jeff beckley is offline
Default converting from fixed pitch to constant speed
I am kicking around the idea of converting my RV7 to constant speed.
I have a lyc A3A hollow crank. I need some advise as to how i would go about this. Like how do I go about converting the crank and does it have to be removed to install the rear plug. What to look for in buying a used setup. AD's and things. Anything would help me .
Jeff Beckley
Des Moines Iowa
Van's RV-7A
Old 11-18-2009, 09:47 AM
jabarr jabarr is offline
See Lycoming SI 1435--
http://www.lycoming.com/support/publ...dfs/SI1435.pdf
Old 11-18-2009, 09:56 AM
charger81 charger81 is offline
Default Your insight as to why you are switching?
I would be very interested to hear why you want to switch. I see FP/CS constantly debated but it is usually more about defending the choice made. You obviously have made the choice to switch so it would be great to hear what about the FP you don't like and why you think CS will be better (as it pertains to your "mission").
Thanks in advance!
Mike
Old 11-18-2009, 10:15 AM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
IMO, many go with the fixed pitch prop because of the initial expense of the constant speed.
I went with the C/S right up front because I knew of all the advantages before hand. I had switched from F/P rentals to C/S rentals a long time ago. There is no way that I would have been content with a fixed pitch RV, and purchasing the Hartzell was probably the number one priority above all else.
Better takeoff performance. Much more choices for landing. Quieter in flight.
Excuses such as C/S maintenance are only that. We re-grease during the condition inspection, and that's about it.
If you just transition from a Cessna 172 or Piper Warrier, to the RV, then you probably wouldn't realize the vast difference between the two props. But if you had flown something more complex, then the difference is quickly obvious...
My choice was made from prior & positive "experience". And BTW, I know of no RV owner around here.............who wouldn't prefer a C/S over their F/P. Just stating the facts.
L.Adamson ---- RV6A Hartzell C/S
Old 11-18-2009, 01:24 PM
Jerry Cochran's Avatar
Jerry Cochran Jerry Cochran is offline
Default Weight diff?
Anyone know the all up weight diff between an alum Sensenich and a two blade Hartzell? I came by a "used" Sensenich and was surprised how heavy it was...
Jerry Cochran
Sherwood, Oregon
RV-7a 707DD Bot from David Domeier 12/01/11
Lycoming IO-360 Catto 3 blade Panel upgrade in progress
RV6a 18XP 1st flite 03/21/07 sold to Dale Walter 10/22/2011
Superior IO-360, Hartzell Blended, GRT/Dynon
Happily "autopaying" DR
"Suppose you were an idiot, and suppose you were a member of Congress; but I repeat myself."
Mark Twain
Old 11-18-2009, 01:38 PM
Radomir's Avatar
Radomir Radomir is offline
It should be around 16lbs.. (Sensenich is 40 and Hartzell around 55 or so)... but you'll almost always gain more if you convert after a while.. somehow planes gain weight over time
Been through that process recently.. it wasn't all that bad...
Radomir
RV-7A sold
Old 11-18-2009, 02:42 PM
sf3543 sf3543 is offline
Default I did it on my RV6
Jeff
Feel free to give me a call to discuss this project. I did it on my RV6, but the discussion is more than I care to type.
210 289-3984
Steve Formhals
A&P, Tech Counselor & Flight Advisor
RV3B
RV8
Old 11-18-2009, 09:51 PM
Right now what i am most interested in is installing the rear plug. What is the procedure for that?
Jeff Beckley
Des Moines Iowa
Van's RV-7A
Old 11-19-2009, 06:44 AM
N941WR's Avatar
N941WR N941WR is offline
There is a Lycoming document that cover how to do that.
In short, I made sure the inside of the crank was clean, put a little RTV on the plug, slid it in place - bubble out, took a long square piece of oak that just fit inside the crank, grabbed a four pound sledge hammer and creamed that thing. The trick is to depress the bubble so it pushes the plug outward, sealing the crank.
If you have one of those newfangled cranks with tubes that cross through it, you might have to modify that wood block a bit or use a long socket extension.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 11-19-2009, 07:07 AM
Sam Buchanan's Avatar
been here awhile
A crank with the oil tube in the center of the bore really does complicate matters. My hangarmate recently made the switch and before all the old rear plug was cleared out a cylinder had to be removed to pick out the remains of the rear plug that had been pushed down the crank. Be sure you have somebody close by who has experience with working around the oil tube if your engine is so equipped. Getting the old rear plug out is the biggest hassle.
Having said that, Bob loves the C/S prop.
Sam Buchanan
RV-6
Fokker D.VII replica
