Old 11-07-2009, 07:14 PM
Greg Arehart's Avatar
Greg Arehart Greg Arehart is offline
Default In-wing camera for aerial photography
[note to DR - I am happy to give this to you, or anyone else, as a PDF file if you would like to put it into the archives that way - it's too big as a Word file}
Being a geologist, I?m always looking at the landscape and have taken a lot of photos out airplane windows over the years. In my work, I also have utilized standard aerial photographs taken by the BLM or other government agencies, but these are taken at odd times and from a standard platform. I was interested in being able to do my own photography so that I could get a broad or close view, or even oblique views, and also so I could do low-sun-angle photography which highlights some geologic features. Normal aerial photos that are commercially available do none of this. So when I started building my 9A, one of the personal modifications I figured I had to have was an in-wing camera. Ideally, this camera would be operable from within the cockpit, and ideally it would be tiltable to get an oblique view if necessary (yes, one can tilt the airplane, but doing so usually results in a turn rather than straight flight).
The solution ended up being fairly simple and this document is for anyone wishing to duplicate my effort, or as a starting point for your own modification.
The first question was where to put the camera, and I decided that the wing bay just outboard of the bellcrank was probably the best place. It is out of the way of any interference with the control rods etc. and is still somewhat near the middle of the wing which was designed to minimize any potential vibration. I calculated the window size necessary to allow the camera to tilt by about 30 degrees forward-aft or left-right, and ended up with a square 8 inches on a side. Since the wing skin is a structural member, I wanted to make certain that I did not compromise wing strength, so I added two ribs parallel to the spar and spaced about 9 inches apart. These were fabricated from 0.032 Al, and lightening holes drilled. Attachments to the original wing ribs were simply 0.032 Al that was riveted to the wing ribs and nutplates added for attachment of the cross-ribs. Thus the cross-ribs are removable if necessary to access other parts of the wing structure. Note in Figure 1 that the cross-ribs are not as thick (top to bottom of the wing) as the original ribs, thus eliminating any potential chafing on the wing skin.
Figure 1. Photograph of the extra wing cross-ribs in the bay outboard of the bellcrank.
I fabricated a backing plate for the camera window from 3/16-inch Al plate (fortunately I have access to the appropriate metalworking tools). In Figure 2, the ultimate resting place for the window is on the step in the center of the plate. The interior dimensions of the opening are 8 x 8 inches, and the step that holds the window is about 3/8? wide. The depth of cut is slightly more than the thickness of the window material (in my case, this is 3/32? plexiglass but one could use whatever dimension is appropriate for the window thickness desired).
Figure 2. Metal backing plate for the plexiglass window fabricated from ?-inch plate stock.
The next step was cutting the wing skin. In Figure 3, you can see the wing skin after cutting to fit the dimensions of the backing plate. In my case, the hole is 8.75? square. I drilled and dimpled holes for 4-40 screws on about 1.25? centers (probably overkill). Figure 3 shows the drilled holes before dimpling. I countersunk the skins and added four rivets (see the odd holes in Figure 4 closeup) to hold the backing plate in place on the skin, but most of the holding power will come from the screws. Screw holes were tapped for 4-40 screws into the Al backing plate.
Figure 3. Backing plate fitted to the wing skin. (apologies for the quality of the photo)
Figure 4. Closeup of the backing plate showing countersinks for the wing skin and one of four rivet holes (the odd-spaced rivet hole, not countersunk as much) that holds the backing plate to the skin.
This finished the skin part of the installation. The camera mount itself is a pair of fabricated boxes (Figure 5). The outside box has a bellcrank bearing (about $25 from ACS) on either side of the long axis of the box, and these are simply bolted onto the cross-ribs, allowing the box to rotate on the roll axis of the airplane. Within this box is a slightly smaller box that is similarly attached to the large box with bellcrank bearings, allowing for rotation in the pitch axis. Although I have not finished the controls for these rotating boxes, they will be driven by radio-controlled car servo motors (available from most RC hobby stores for about $25) that are wired to a pair of rheostats in the cockpit. Figure 5 shows a test installation ? the final installation (Figure 6) used an aluminum tube spacer rather than the wood one.
Figure 5. Nested camera boxes. It is important to get the holes in the two ribs in the right places so that the outer box can rotate freely.
The camera (I use a Canon Powershot G9,12 megapixel camera, but any good quality camera would do) is just mounted within the smaller box using a standard threaded tripod mount bolt with a knurled knob. I actually ended up fabricating a couple of Z-brackets to make sure that the camera would stay in place (Figure 6). The camera is padded all around the Z-brackets and the back using that rubberized, webby shelf padding available at Lowes or other home stores. This helps minimize vibrations and rubbing.
Greg Arehart
RV-9B (Big tires) Tipup @AJZ or CYSQ
N 7965A
Old 11-07-2009, 07:15 PM
Default Part 2 of 3
Figure 6. Camera in place showing the Z-brackets that help stabilize the camera. In the background the power wires for the tilt servos can be seen, but the servos have not been installed yet. Hey, the airplane got painted!
From this bay, I ran the following wires into the cockpit: 1) USB cable (have to cut one end off to get it through the holes etc.); 2) two wires for the servo motors that will drive the pitch and roll axes; 3) a power wire for the camera; and 4) a pair of wires to run the on-off switch on the camera.
Power for the camera is supplied via a 3-terminal regulator. The regulator circuit consists of a L78S75CV 7.5V 2A regulator and a 0.1uf cap on the input and a 1uf cap on the output. The caps are epoxied on to the regulator and mounted with a single screw to the wing rib in the camera bay (Figure 7). We then built a small battery replacement, so that the camera runs off ship?s power ? no need to ever change batteries!
Figure 7. Voltage regulator for camera (mostly too small to see easily in this photo) attached to one of the ribs.
Providing the remote turn-on for the camera was a little challenging because the circuitry of most cameras is surface mount on circuit films, but the camera was opened up and the power switch, which is about 4mm square, was removed and two wires were soldered to the switch circuit pads to be connected to a normally-open push button switch on the instrument panel (Figure 8). A drop of silicone rubber was put on the wires where they were soldered to the circuit board and the wires were looped around the camera strap eye for strain relief. Warning! It is very easy to ruin surface mount circuit films so you need a very fine tip, temperature-regulated soldering iron and a steady hand. A 100W soldering gun isn?t going to cut it.
Figure 8 shows the panel switches. The tiny toggle is camera power, and the red PTT turns the camera on and off. The two brass screws are where the rheostats will end up for controlling the pitch and roll servos.
Figure 8. Panel controls. The tiny toggle below the red button is the power supply. The red button is the camera on-off switch (normally open). The two brass screws in the center of the inset panel will eventually be the rheostat controls for the tilt servos.
The entire camera operation is controlled from within the cockpit (preferably by the passenger so the pilot can fly) using a laptop computer through the USB cable. I use a program from Breeze Systems, Inc. that allows remote control of the camera. They have programs for a number of cameras currently on the market, and it?s probably worth making sure that you can find a camera that works with the remote software before installing in your wing. I think the cost was $50 for the software. It has a live viewfinder (full or partial screen), and one can control all of the normal camera functions from the laptop (not sure about the flash, but probably so, even though I would never use it). Taking a photo is as simple as pushing a button. I normally operate at 1/1000 second exposure and have infinite depth of field. I have taken photos from 50 feet AGL at 150 mph with essentially no blurriness using this setting, but its worth testing for your particular setup. Reload time between photos is about 1/3 to ? second, so it is easy to get multiple photos quickly. I find that flying at 4000? AGL, I get about 50% overlap between photos (allowing for stereo viewing) by taking photos at about 4-5 second intervals. One must shoot faster when flying lower.
Figure 9. Cover plates for the window. The L one is installed when I don?t figure I will likely be using the camera. The R one is normally installed to hold the window in place when the camera is operative.
Figure 10. Final installation viewed from the wingtip.
I would be happy to answer questions, provide info etc. Next post will contain some example photos.
greg
Greg Arehart
N 7965A
Old 11-07-2009, 07:26 PM
Default Part 3 of 3 - example photos
One of these photos is rather large, so I have just provided a thumbnail and a link. The image quality in all of the embedded photos has been downgraded to fit 800 x 600 format.
Herlong (CA) prison from 5000 AGL
Herlong prison from 1100 AGL. Worth going to the original and zooming in to read messages from the prisoners!
Sierra Army Depot tank storage from 2500 AGL
Owyhee River (OR) from about 3000 AGL
Panum Crater near Mono Lake CA from 5000 AGL
Cow tracks in sand dunes from about 100 AGL and 140 mph.
Am I having fun or what!
greg
Greg Arehart
N 7965A
Old 11-07-2009, 07:49 PM
Greg two questions regarding your setup.
First - how difficult would it be to install similar setup in already closed wing?
Second - how much may it cost to machine two metal backing plates?
Old 11-07-2009, 08:00 PM
diamond diamond is offline
Exceptional work Greg. Maybe I missed it in your document, but how difficult would it be to replace the camera should it fail or you decide to upgrade as technology gets more sophisticated?
Old 11-07-2009, 08:10 PM
N941WR's Avatar
N941WR N941WR is offline
Greg,
That looks great! As I was reading your thread, you could always blow a bubble cover, that would allow a longer camera to sit in your wing.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 11-07-2009, 08:41 PM
Alex Alex is offline
Default Great stuff, so many questions!
Very cool. I have a few questions if you don't mind. Why did you mount it into the structure of the wing rather than in an external pod of some sort? And for that matter why did you locate it in the wing and not the fuselage? Did you consider using a gimballed mirror with a fixed camera? Does the software you use tag the photos with GPS lat/lon or stitch mosaics? Thanks, Alex
Alex Roup
RV-12 (empennage) #120407
Northern VA
Old 11-07-2009, 08:56 PM
frankh's Avatar
frankh frankh is offline
That is seriously cool!
Frank
Old 11-07-2009, 09:50 PM
Bevan Bevan is offline
Default Spectacular
Awesome concept and execution. Well done!
Bevan
Old 11-08-2009, 09:38 AM
GAHco's Avatar
GAHco GAHco is offline
Thumbs up Looks pretty cool!
That would almost make you a secret agent man.
Nice photos too.
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
